Question about Sony XVM-R70 7 in. Car Monitor
Headrest monitors flickering
My headrest monitors fliker on and off when I am playing a movie. Does anyone know what is caused by this or how to fix it!
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
I have a forj dvd72hr headrest dual dvd player and I'm trying to get movies to play from an SD card but so far they won't play the formats I have done (MP4,AVI,and MKV) anyone know anything about this??
You can put the SD cards in the player? or did you try to burn the video on a DVD?
The last will only work if you recode the MP4 AVI or whatever, back to the original DVD format. You can make a region free DVD.
Jun 22, 2014 | Audio Players & Recorders
Invision headrest dvd wiring diagram
Call the dealer parts department or go to an aftermarket stereo installer. They will be able to give you the location information.
Mar 28, 2014 | 2009 Buick Enclave
Where can I find a hummer h3 original headrest control box? I have a headrest DVD player and my box got damage by water. If anyone know or have one for sale please let me know........
que ce que ca veut dire
Where can I find a hummer h3 original headrest control box? I have a headrest DVD player and my box got damage by water. If anyone know or have one for sale please let me know..... rodneyzayas@yahoo.com Thanks
Aug 16, 2013 | Car Audio & Video
Auto adjustment locked and picture is fliker
Its not auto adjusting because of the flickering. Its flickering because the screen itself is losing voltage so it cant stay on. You can try hooking up the monitor to another computer just to rule out a bad video card but it looks like replacing the LCD is the only solution.
May 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Flickering screen
take it back its a known issue and acer isnt telling anyone
May 08, 2010 | Acer AL1916W 19" LCD Monitor
Ive got the screen hooked up to my lap top everything looks great but when i play a movie the screen flickers
Screens will flicker during movies if the monitor settings or drivers are incorrect.
Check to make sure that the drivers for that model monitor are installed and up to date.
Go into control panel>display>settings>advanced>Monitor
and try changing the screen refresh rate (Hertz). You can also adjust the resolution from the settings screen as well.
Dec 21, 2009 | LG W2353V-PF 23' LCD Monitor
Phillips mx3660d dvd player with surround sound system overheats about 45 minutes into a movie and then shuts down. Once it cools down you can turn it back on and finish the movie. Does anyone know what is...
my phillips mx 3660D digital surround dvd system won't read the movies any more it says no disc.It will play music cd's beautifully ok whats the problem? help it was playing fine
Oct 18, 2009 | Philips Magnavox DVD/VCR Dual Player
Can hear sound from front 2 headrest but not back 2 (T-view 10'')
sounds like you have a couple of problems. 1) your headrests accessory wire is not hooked up or it doesnt have one, that would fix your problem with the movies starting all over again. check this by changing your color really high or low on a monitor turn the key off wait a few seconds then on again then check to see if the color stayed the same, if it did then you may have low quality or off brand monitors. 2) the sound issue could be kind of tricky the rear headrests may be hooked up but you may need to turn the sound on trough the head unit and this all depends on the make and model you have. i would suggest you take this to your local stereo shop or wherever you had it originally intalled. they should be able to check this out for you.
Nov 24, 2008 | Car Audio & Video
Sony XVM-R70 7 in. Car Monitor Logo
215 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
