Question about Electrolux EMS2487X Convection Microwave Oven
Microwave light is on, dish is moving but no heating
  • Electrolux Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Why does our new microwave not work? Can set the time and it counts down when we have pressed start but does nothing else.
There is a big fuse inside that thing. Check to see that it is not open. Could be that the magnetron, lite, and dish are all on the same circuit.
Sep 21, 2015 | Daewoo KOR6N9RR Microwave Oven
While our microwave is running, there is popping sounds and the panel on the side is sparking
take out the tray and the carousel and put something in the microwave and try to heat it,no zapping means faulty carousel or tray,if you used the microwave with nothing in it,then the microwave WILL do that{zap},do not use your microwave without anything in it,if this still happens,replace the microwave,or you have metal in the dishes you are using.stop using the dishes,get microwave safe dishes.
Jan 03, 2015 | Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
When attempting to use the microwave oven, the light goes on, the glass dish spins, but no heat actually is applied. What can we do to fix this or who exactly do we contact for this?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 16, 2011 | Whirlpool MH7135XE Microwave Oven
This unit has lights, fan works, inside dish rotates, BUT does not heat or defrost. Can you help?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 10, 2010 | GE JE1640 Microwave Oven
The dish inside the microwave has no movement. It normally moves
If power in on. Just check out to see if the plastic conection may have broke that conects the dish and holder to motor.
May 09, 2010 | Panasonic NN-S505 1200 Watts Microwave...
Microwave won't heat up light comes on and dish turns but thats it
either the h.v diode or capacitor,thermal fuse or magnetron are bad
Oct 28, 2009 | Microwave Ovens
Microwave doesn't work
There is a reset somewhere around the top or close to heating element
Mar 12, 2009 | LG Over-the-Range Microwave
Electrolux EMS2487X Convection Microwave Oven Logo
176 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
