Question about Compaq Evo D510 PC Desktop
When booting up xp pro the system will not boot sound video and no lan connection
  • 148 Answers
Go to system properties --- Hardware Tab and then device manager. Check whether there are yello mark on both sound and LAN. If yes, then reinstall the drivers for the same.
Posted on Apr 13, 2009
Hi Everyone , After trying to solve the start up
After this reply you will still not be able to start normally.
The boot to lan is trying to start off an image stored on a server, you normally only see this at a business.
Boot to CD is looking for a bootable CD like the disk used to install Windows.
Boot to hard drive is normal but from your post it appears that it cannot communicate with your hard drive. Normally, when you have hard drives issues, the file is corrupt and at this point the computer complains but is sounds like it just freezes which suggests to me that the controller is gone.
In short, in order to get this working you will probably have to buy a new hard drive and reinstall Windows from CD. Since the version of Windows you have is XP (if you have the disk) and support for it ended almost 3 years ago, you are probably better off just getting a new laptop. https://www.microsoft.com/en-us/windowsforbusiness/end-of-xp-support
Mar 04, 2017 | HP PAVILION DV4000 AND V4000 SERIES...
I have no idea if I'm even in the right ball park, but anyways, I have a Pentium 4 3.0 Ghz laptop that on the top cover says Syntax, on the bottom it says Model No. GREEN736 Serial No....
Going from No wifi connection to reinstalling windows is a big difference in time and maybe documents. If your sure you can't boot and want to reinstall xp the best would be to go into your bios. Its F12 or whatever on your machine just so you get to the bios. There you can select a certain amount of memory that you have to be partioned. Simply all would go for your xp installation. With the xp disk in the drive turn on the machine and it should boot to the installation. If it doesn't your boot order is incorrect meaning the machine is trying to boot from the hard drive and you want the machine to boot from your dvd drive. So in the bios you have to make sure the default boot at least temporarily is the dvd drive. When in the bios that is real simple to change.
With the computer instructed to boot from dvd drive and disc in the dvd drive it will jump to the installation of the xp pro. If you have any questions come back with another and you should get a response as this is a fairly common question
Apr 06, 2011 | Syntax Computers & Internet
Windows XP Pro hangs on resume from standby or hibernate
There are many reasons this can happen, and unfortunately very difficult to pinpoint the issue in a particular case.
1. In your system BIOS there is usually two sleep mode (power states) you can select. It is Usually set to S3, change it to S1 (or vice versa), and disable wake on LAN (if available) unless you need it
2. Attempt a clean boot and see if some background startup item or service is causing the issue. see this article for troubleshooting startup items
3. Make sure you drivers (especially chipset, network, video and sound) and BIOS are up to date.
4. Disconnect as many things as you can (boot with just your keyboard, mouse and monitor) try a different mouse and keyboard.
I hope you find the cause, also check in Event Viewer to see if there are corresponding errors
Feb 05, 2009 | Microsoft Windows XP Professional With...
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from...
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Jul 22, 2008 | Computers & Internet
Booting up windows xp pro on dimension 4700
hmmm..not too happy..sounds like your video card is not too good...try it in safe mode(F8) and then check the video card in control panel, then system, then device manager. make sure driver is clean.
got backup?
Feb 19, 2008 | Dell Dimension 4700 PC Desktop
Xp format problem
Assuming that you have both XP's on the drive, when it boots up, have you selected and tested both? OR
Did you format the entire drive and wipe the old system off, replacing it with the new install?
The simplest why to fix is to boot up on the Pro CD and format the entire drive and install new system. It sounds like your old info may still be there, but you can't get to it. Try the different boot option and burn your desired data to keep to a cd, then do the simplest. Don't worry about the system drivers, you can recover them from the restore cd or download them from the Dell.
The Pro XP will be able to recover your system enough to get the drivers on line.
No big deal, just time consuming.
Good Luck
Feb 14, 2008 | Dell Dimension 2400 PC Desktop
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
Windows XP Pro installed but computer boots to Home Edition
It sure is possible.
I would take it back to them and demand that WINXP Pro is put back in there and it boot correctly
They saved about 50 bucks putting in WINXP Home.
Sounds like a bunch of rookies trying to pull a fast one.
Nov 13, 2007 | Microsoft Windows XP Professional for PC
Compaq Evo D510 PC Desktop Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
