Question about Sylvania 6427TE 27" TV
Sylvania T.V. Remote
I lost the manual that tells you how to program the remote.
SOURCE: rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
Posted on Jun 03, 2008
SOURCE: Sylvania 6419TC
My Sylvania T.V. only stays on for 1minute then it shuts off.
Posted on Sep 01, 2008
SOURCE: Sylvania TV stuck in Game mode remote no longer works
just go to channel setup and add/delete channel, it should exit the game mode. then do nothing unti the add/delete option exits the bottom of the screen.
Posted on Sep 14, 2008
  • 949 Answers
SOURCE: i lost the remote to my sylvania model; 6419TE 19
Have you tried the search fuction,some of the remotes will search for a code that works.
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: How did you get the sylvania tv into game mode with out remote
I had to use a dishnetwork remote that I had lying around. You also may able to program a direct tv remote, replaytv remote or universal remote. I have found that putting it into 'game mode' does not work. You will not be able to change the input without a remote.
Here are the instructions for the dishnetwork remote I was using (may differ slightly from yours):
Sylvania Television codes: 733, 506, 525, 536, 566, 568, 569, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729
1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
2. Look up the Code(s) for the piece of equipment you are trying to address. If the equipment is not listed or a Power Scan is desired click here.
3. Press and hold the correct Mode button (about six seconds) until all mode button backlights come on, then release.
4. Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
6. To verify the code works, press the mode button. Then try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
7. Store the remote code for future use.
8. If the remote still does not operate the device, perform the Power Scan. If still no operation, it may not be compatible with that piece of equipment.
Posted on Jul 30, 2009
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
0 characters
1 Points
How do i get my LM-1750 remote control to operate my sylvania 6427FF television
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 09, 2014 | Sylvania 6427FF TV
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Apr 08, 2012 | Sylvania 6432GG 32" TV
Need to program tv to a universal remote control
Here are some codes for sylvania - depending on the remote they may work - 019,801,002,009,109,117,209,309,402,408,502,508,717,807&914
Sep 27, 2009 | Sylvania Standard (CRT) Televisions
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
Jun 13, 2009 | Sylvania 6420FB 20" TV
well, i got a one for all remote from a wal mart or some where else, and i have a sylvania tv. it works for my tv. might want to look into that.
May 27, 2009 | Sylvania Standard (CRT) Televisions
I need to re-program my GE universal remote to my Sylvania TV
see if you can find your GE universal remote at a store where you got it from or any store, best buy, target,, walmart, up the package and write down the instructions or code numbers :-) hope that helps and good luck
Apr 07, 2009 | Sylvania Standard (CRT) Televisions
Please help!
The code for the Sylvania 6432te 32" TV with the "Innovage products- Jumbo universal remote" is 189. you push and hold down the code search button, when the light starts to flash, hit tv, then the number "189". Finally, push the power button off on the remote control. if the tv turns off, then it worked. :)
Nov 05, 2008 | Sylvania 6432TE 32" TV
Lost Remote
I got mine off of game mode by using a universal remote. I had to type in a channel, (03) and it got it out of game mode, but I now have the problem of not being able to get it back into game mode so that I can use my DVD player. Good luck
Feb 07, 2008 | ESA EF402E 20" TV
No remote
Sadly you cant
Dec 06, 2007 | Sylvania 6427TE 27" TV
Sylvania 6427TE 27" TV Logo
240 people viewed this question
Top Sylvania Standard (CRT) Televisions Experts
Kenneth Walker
Are you a Sylvania Standard (CRT) Television Expert? Answer questions, earn points and help others
