Question about Stoves 720EF Electric Double Oven
KNOB ON GRILL BROKEN CAN I BUY PART. LITTLE METAL PART ON INSIDE OF KNOB MISSING.
  • 250 Answers
Try ESPARES. If the website does not show it, send them a mail asking for a quote.
Posted on Apr 18, 2009
Hi I have a 720GRa rotostar double oven and grill when I turn the top oven/grill knob it turns but nothing works eg lights on the front the fan or the ignition but the oven works fine it worked this...
I suggest that if you have more than one knob of the same type, these knobs are usually removable by pulling straight out. Pull the knobs out and compare the inside. I would not be surprised if a metal insert is missing or the inside is stripped. Hope this suggestion is helpful.
Nov 20, 2014 | Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Ra610 thermostat
is easy the probe inside the oven is helt there by two clips,remove back off oven after turning off the power to it pull off knob undo nut with long nose pliers and remove change wires over one by one so they are connected right pull out old probe push new probe in though the back to the inside of oven and clip into place
Nov 07, 2013 | Fisher and Paykel Ovens
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
Need switch for stove model 720ef that when turned anti clockwise puts on half off grill and when turned clockwise puts on the whole grill where can i buy one
Sounds like maybe u just need the knob.u can call repair clinic the number is 1866-822-0890 or 1-800-269-2609 they of most parts on hand .I order my parts first day and alwas get them the next day .
Nov 09, 2011 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
The grill / top oven knob will not operate the grill any suggestions?
It is possible the knob is slipping round and not turning the spindle of the switch, or the spindle is broken inside the switch, or the switch is partially seized up.
Pull the kjnob off the switch, and try turning it on wioth pair of pliers or grips, if that works, then the switch is probably o/k.
Also spray some WD40 onto the switch spindle, and inside the switch.
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
Hotpoint eg76x grill
If the grill is working in some positions on the switch but not in others it sounds like the switch under the knob may be the problem. Does the same switch control the fan? If yes I would say you will have to replace that switch and that the contacts more than likely are worn inside the switch. Switches are usually not hard to replace and usually have lugs or a push/pull connector. Make sure you TURN OFF the POWER before you start trying to remove it. Hope this helps.
Regards
Bryan
Feb 17, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
128 people viewed this question
Top Stoves Ovens Experts
ashburton
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
