Question about Samsung CLP 300 Laser Printer
Printer starts to print but then stops
Green light on, press print, it starts to wind up and then just stops, showing red light. I have opened rear access hatch and closed it a few times and it starts, that 'fix' has now ceased to operate. Removing paper tray and reinserting it has sometimes solved the problem but that has also ceased to work I'm out of options unless someone can help
Thanks
  • coopr Apr 18, 2009
    Yep, same issue here - printed worked perfectly for months, but now it seems like every few prints it'll do this. I can usually get it to finish printing by opening the back cover, the top cover, the front cover, partly removing the toner pack, and removing the paper tray - they reassembling the whole damn thing!
    Problem Solver:
  • 6 Answers
Try cleaning the rubber roller that picks up the paper from the tray with aocohol
Posted on Jan 10, 2010
Testimonial: "it worked thanks"
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have conon mx 868 but i have got error message 6502 and 150 how can i solve the problem?
Here are instructions:
The MPTool is designed for service works with the printer Canon MP-Series
when in Low-Level mode. This is NOT the same as "service mode"
Currently supported for
MP150, MP160, MP170, MP180, MP450, MP460. MP150, MP160, MP170, MP180, MP450, MP460.
BEFORE activating MPTool...you need to
To activate LOW LEVEL mode:
1. Unplug the power cord to the printer for a moment.
2. Then, hold down the on/off button while plugging in the power cord. Keep holding the on/off button down.
3. Right away the green power light (in the button) will turn on solid. Keep holding the on/off button down.
4. Press and release the Stop/Reset button.
(the button w a red triangle in a red circle)
5. Now you can release the on/off putton.
The green power light will go off and the yellow Alarm light will stay on.
Now you can run MPTOOL and resetting the ink counters will work.
Your printer will show up as "another" Cannon printer.
When you finish you must again unplug the power cord for a moment and then just plug it back in. After you do this, you'll see both printers listed in Printers (controll panel) and one will show as offline. You can then rename this offline printer as "Low Mode Canon"
or whatever works for you so you don't mix it up with other functions.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
For
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Reset manual "Ink Absorber Full"
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again
Canon MPC INKTank FULL
button pressing
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Apr 08, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
My printer MP140 Shows error E27
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
The number of the Reset button pressing LED Function Remarks
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Dec 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
My printer show error e28, help solve it, please
E28 = Ink cartridge temperature rise error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Unplug cable power.
Aug 04, 2009 | Canon Office Equipment & Supplies
Inktank problem with mp130
hi
it's show u a red/orange light blink it's show u hae a refield cartig insarted u need to press red light buttons for 5sec. and then light blink off and only green light only show now give pring if again orange light blink press 5sec. don't give any kind of link on show messages in windows it's gone automaticaly if u have any quary please tell me...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
Service mode operation procedures -
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Samsung CLP 300 Laser Printer Logo
363 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
