Question about Lands Phones
Inside phone wiring
I have Bellsouth, now AT&T. When they last serviced my DSL they disconnected the wires so I cant use the telephone jack in my bedroom-which I could before. They forgot to reconnect it after they finished troublshooting my DSL. I really dont want to wait for them to come back and wait around for an appt. I would like to know...when I took off the jack from the wall, I see there are 2 wires or cables inside the wall. I dont know which one to hook up. One comes from the top, and 1 from the bottom. Both are coated in white plastic with several colored wires inside. How do I know which is for my bedroom? Also, I see that only the red and green wires are used. Do I just take those and wrap them around the voice 1 tip and ring along with the oen thats there already (probably from my kitchen phone)? I have a POTS Splitter for bellsouth, wall mount installed.Thank you very much!
    Problem Solver:
  • 12 Answers
If they used the old wiring red and green would work if it is newer cat 3 or five wiring it would be white with bule both have the same coclor band on them ex white w blus stripe and blue with white stripe this would only work if the wire is active to this location
Posted on Sep 13, 2007
    Novelist:
  • 201 Answers
Red and green (2-wires) are all that is typically needed. This does depend on if the other end of the wire is properly hooked up!
Posted on Sep 12, 2007
Our cordless phone says check tel line we have unplugged and plugged back in nothing called phone company they said everything was fine still our phone isnt working
You probably have a telephone wiring problem inside your home or your cordless telephone base has failed. I like to use an old corded phone for diagnostics. If you have other phones connected to the same phone line, make sure that all handsets are in standby/on hook.
First, try a different RJ-11 cable between the jack and the base. (Note: I have seen someone use a handset cord here. It doesn't work so make sure that the correct cable is in use.) If the "check tel line" message persists, connect the test phone to the jack with the RJ-11 cable. Do you hear a dial tone? If you do, then the cordless phone base has malfunctioned. If it is under warranty, contact the manufacturer. Otherwise, replace the phone.
If neither phone gets a dial tone, check if the test phone hears a dial tone at another jack on the same line, if you have one. If you have a dial tone here, then you know that the wires in the first jack or between the service box and the jack have a problem. Check the jack. There are two types of jacks: keystone and screw connections. Look for any loose conductors. For a keystone jack, you will need a punch-down tool, available at most hardware stores in the wiring section. Do not strip the wire; just push it back into the correct spot in the keystone. For screw-type jacks, strip the wire and secure it under the correct screw. See http://www.lanshack.com/wire_phone_jack.aspx for the pattern.
Find your service box. Check if any wires are dangling. I had a service upgrade where the wiring for one jack was left loose behind the siding. Once that wire was connected to the new box, all of the jacks worked. Even though the telephone company said that the service was good, try your test phone if there is an RJ-11 jack in the service box. If you do not have a dial tone, get your phone company to send a technician. The outside wiring needs to be repaired. (Most companies should repair this for free. However, some companies are trying to get more people switched to other service types.)
Do you have a DSL line? If so, where is the DSL filter? If your filter is inside, you may need to replace it. If it is part of the service box, your telephone company technician should fix it for you.
If your phone line has a dial tone at the service box and the problem isn't in the jack, then you may want to hire a professional to fix a wiring problem in the wall. Most telephone companies will provide a technician to do this for a fee.
I hope this helps.
(I have had mice damage copper wire leading to a phone line outage. Other external wiring problems were due to contractors digging too close to the phone line. With a fiber-optic service, when the modem in the service box failed, the phone lost the line and dial tone.)
Sep 16, 2017 | Lands Phones
All 4 hand units say "line in use" How do exit tis situation? hand units model KX-TGA410, baseunit KX-TGA131
A "Line in Use" message generally means that there is no dial tone detected. Assuming that all of the handsets are in Standby and any other phones are connected to that line are also on their hooks, then you need to determine why the base isn't getting a dial tone. This can be an inside or outside wiring problem.
I like to use an old wired telephone for testing since power isn't required to use the phone. You also need another RJ-11 telephone wire. Try connecting a new RJ-11 wire between the KX-TGA131 base and the phone jack. If there is a dial tone with the new cable, you had a bad cable. If not, try the alternate phone. If the test phone has a dial tone, then the KX-TGA131 has failed or has a power problem. If the phone is under warranty, contact Panasonic.
If neither phone has a dial tone, take your test phone to another jack connected to the same phone line (number), if available. If you have a dial tone here, then the problem is in the first jack or the wiring to the jack. You can try to repair the jack yourself. Remove the cover plate and look at the jack. If any wires are loose, reconnect them to their appropriate location. See http://www.lanshack.com/wire_phone_jack.aspx for the usual patterns. There are two types of telephone jacks, keystone and screw terminals. For the keystone type, you need a punch-down tool (available at many hardware stores in the electrical section) to put the wires back in place. Do not strip the individual conductors before using the punch down tool. For screw terminals, strip the wire before securing it under the screw.
If you do not have another jack or there is no dial tone at the second jack, find the incoming telephone service box. Open the box and check the wiring. If you find an RJ-11 jack, plug in your test phone and listen for a dial tone. If there is a dial tone, you have a wiring problem. Check the jacks as above. You may want to have someone else check the wiring in the walls if there are no broken/loose wires in the jacks. Your telephone company will usually offer the service for a fee.
If you can't test the phone line at the service box or there is no dial tone at the service box, contact your telephone company. They will test the service box and should repair outside issues for free. (Some providers are trying to avoid copper repairs.)
If you have DSL, you may need to check the line filter. This filter can disrupt the dial tone when it fails. If the filter is in the interior, you are responsible for the replacement. In my service area, the DSL filter was in the service box so my telephone company repaired it.
I hope this helps.
(I've had no line issues several times. Sometimes, it was the result of a contractor cutting through underground lines. With copper wire, rodents sometimes damaged those underground wires. Once it was simply an issue of a contractor who'd left one wire loose after upgrading the service.)
Aug 26, 2017 | Lands Phones
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
Dsl hooked up first then phone. worked fine for a while now nothing on phone but internt works. why
It could be one of several issues. I'd first check and replace the DSL filter. These can get damaged during a thunderstorm, even if there is no direct lightning strike. (Some filters may be in the service box and should be replaced by the telephone company repair crew.) Next check your phone line at several jacks, including the service box connection, if you can. I like to use an old wired phone to check for dial tone; an old rotary phone is my preferred tool since it rarely fails. Not all phone services have an RJ-11 connection in the service box. In that case, you need to contact the phone company to test the service.
If you have a dial tone at the service box and not at other jacks, you'll need to check for damaged wires in your walls and jacks. The jacks are fairly easy to check. They either have screw terminals or keystones. For the screw terminals, you strip a new section of the broken conductor wire and place it under the appropriate screw. For keystones, you do not strip the wire; just push in the wire with a punch down tool. The tools are available at most hardware stores in the electrical section. See http://cablesupply.com/content/47-telephone-connections-and-rj11 for the wire color to terminal location. Your phone company will correct inside wiring issues for a fee.
If you do not have a dial tone at the service connection, your telephone provider will fix the problem for free. There is probably a damaged wire outside your home.
If your spare phone gets a dial tone, then the original phone has a problem. If it is a cordless phone, check that the base unit has power. Next check that the handset batteries are good. Replace the unit or have it serviced if the transmitters or receivers can't communicate.
I hope this helps.
Jun 21, 2015 | Office Equipment & Supplies
Why does my panasonic cordless home phone have the error message "check tell line?"
I like to use an old corded phone to diagnose telephone line problems. First though, try a new telephone cord between the base and the phone jack. (This can be obvious to some but I once saw a person swap a handset cord (the coiled cord) and an RJ-11 cable.)
Next plug a different phone into the jack. If it gets a dial tone, the KXTGA470B needs service. (If it is out of warranty, it may be better to replace it.) If the second phone does not get a dial tone, try the spare phone at a different jack if there is one. If the phone gets a dial tone at this jack, your wiring to the jack or inside it is faulty. I'd check the jack first, unscrew the faceplate and look at the back of the unit. There are two types of jacks. One has all of the conductor wires connect to screw terminals. If any wire is broken, strip the shielding from a bit more of the wire. Then wrap the wire under the appropriate screw. The other type of jack is a keystone. If a wire is loose, you'll need a punch-down tool (available at many hardware stores in the wiring section). Do not strip the wire, just press a new section into the correct point on the keystone. See http://www.lanshack.com/wire_phone_jack.aspx for the pin assignments.
If there isn't another phone line jack or there is no dial tone at another jack, find where your telephone service comes in. Open the box and look inside. If you are lucky, the service will have an RJ-11 connection. Plug in your test phone and check for dial tone. If there is still no dial tone, call your phone company and tell them to fix it. (I've had mice chew wires in underground service.) It will be a free repair. If there is a dial tone here, you've confirmed an inside wiring issue. One thing to check while you are at the box: since you have multiple jacks, check that all of the wires connect to the box. We had our service upgraded and they forgot to wire one jack to the new service box. (It was obvious when we went to the box; the wire was just floating behind the house's vinyl siding.)
Next consider your service type, if you have DSL with your phone service, check the filter. Some phone companies have these inside the home and you are responsible for it. Lightning strikes nearby can damage them and interrupt the phone line. Otherwise, since you didn't see any breaks in the wires when you inspected them, you may want a professional to check the wiring. It's possible to have one broken conductor within the shielding. (One way to test this is to swap the wires at the service box and the jack. Most RJ-11 lines are 4 or 6 wires. Two wires are needed for each line. Use the diagram I linked to above and physically connect the R2 and T2 lines to the R1 pins.) Some telephone companies will do indoor repairs for a fee.
If the service box doesn't have an RJ-11 connection or you have an outside DSL filter, ask them to send someone out to physically check the service. (Just because their computer says it is up, doesn't mean it is. I've seen it happen.)
I hope this helps.
(My preferred test phone is an old rotary unit. It never fails unlike some newer phones.)
Aug 01, 2014 | Panasonic KXTGA470B KX-TGA470B KX TGA470B...
Parallel set on how can i get it off
Parallel Set indicates that the CS5121 thinks that another extension is in use on the phone line. First check that no other phones are off their hook. (I have a few that can be tricky to hang up.) If you have no other extensions or if they are on hook, then you need to check if the problem is with your VTech phone or with your phone line.
For diagnostics, I like to use an old corded phone. First try a new telephone cord (RJ-11) to the base of your CS5121. Then if the problem persists, try the new phone cord with the test phone. Listen for a normal dial tone. If you hear a fast busy signal or no dial tone, try the test phone at a different jack on that phone line (if you have one). If you still do not have a normal dial tone, find where the telephone service comes into your building. Open the service box and identify the type of connection. If you are lucky, the service box has RJ-11 jacks. Try your test phone there. If you can't test the phone line or the problem persists, contact your telephone company. They will test the line and repair any outside problem for free.
If it is an inside wiring problem, inspect the wires that are in the open for damage. If only one jack is the problem, open the face plate and check for loose wires. There are two types of connections in telephone faceplates: screw terminals or punch down jacks. The wires need to be stripped (enough to go under the screw) and then secured by the screw for the first type. For a punch down jack, you will need a tool to secure the wires. The tool is available at many home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for the wiring order for an RJ-11 jack. If the problem is inside the wall, you may want to get a professional to fix the problem. Your telephone company will do this for a fee. If you have a DSL filter as part of your phone line, you may need to replace this. (At my house this is part of the outside wiring and gets fixed by the phone company. My sister has the filter as part of the inside wiring and has to fix it herself.)
If only your CS5121 has a problem, try removing the battery pack from the handset. Next unplug the telephone cable and the power adapter from the base. Unplug the power adapter from the wall outlet, as well. Wait a few minutes, then reconnect the power and phone line cord. Then reconnect the handset battery. Test your phone again. If it still gives you a problem, contact Vtech for service if it is under warranty. These phones are not user serviceable.
I hope this helps.
Nov 29, 2011 | Vtech CS5121 Cordless Phone
My KX-TG6511 Phone is in it's cradle but line in use message shows. It's the only one on that line
Check your phone line with a) a new cord between the base and the jack and b) a different phone (I prefer an old cordless phone). If you still get a "line in use" message (alternate errors: fast busy signal or no dial tone), use your test phone at a different jack and determine if the issue persists. If you can, find where your phone service comes in and open the box. If you are lucky and have a fairly new service connection, you'll be able to plug your RJ-11 phone line in and check if there is the problem is at the box. If you can't test at this point, you need to contact your phone company to diagnose if the problem is inside or outside.
If the problem is only with the KX-TG65111 phone, try unplugging the base from the phone line and the cord from the wall jack, disconnecting the base AC power cord (from both sides - phone first) and removing the batteries the handset. After a few minutes, plug in phone line, power cord and batteries and test again. If it still fails, then the phone needs service. These cordless phones are not designed for the home user to service. If the phone is under warranty, contact Panasonic. Otherwise, decide if it is worth having the unit serviced or replacing.
If no phone works at this one jack but does work at another jack, you have a wiring problem at the jack or in the wall to the jack. Try opening up the outlet and check for loose or damaged wires. The jack is either wired directly to screw terminals or punch down terminals. For the screws, it's relatively easy to strip the insulation and retighten the connections. For the punch down style, you will need the appropriate tool. (It's available from many hardware stores in the wiring section.) See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the pins in the jack wiring.
If none of your inside jacks work, look at the exposed wiring and check for any obvious damage. Otherwise, you'll need to find the problem in the walls. You may want a professional to do the job.
If the problem is outside, your phone company will fix the probem for you for free. If the problem is inside, they'll fix the problem for a fee.
If you have a DSL line and a filter on the line, check and replace that if it is part of your inside wiring.
I hope this helps.
(I've gotten a line in use error with a DSL filter problem after a nearby lightning strike. Since my filter is inside the service box, my telephone company handled the repair.)
Nov 21, 2011 | Panasonic KX TG6511 Cordless Phone
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Dsl wire disconnected
If the wire is blue, or yellow in color , and it connector appears like a telephone jack , but a little bigger than the same..
One end of this cable would connect to the nextwork jack at the back of your computer , and the other end would connect to the DSL modem box that you have.
Thanks
Proton
Apr 30, 2009 | E-Machines eMachines Desktop PC
Phones Dead but DSL OK
A short inside the house should also disable the DSL service, but you can rule out this possibility by disconnecting the inside wiring from the outside wiring at the entrance box. If you still can't get a dial tone when you clip onto the incoming wires, then you need to contact your local phone company to have them find the problem and restore your phone service.
Good luck...and I hope this is helpfull!!
Jan 26, 2008 | Lands Phones
Lands Phones Logo
143 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
