Question about RIM BlackBerry 7290
Blackberry not on Home screen
My 7290 just displays 4 lines, 1st line Blackberry Platform 1.8.0.154, 2nd line SaedMessages, 3rd line Options, and 4th line Pocket Express. No scroll home screen, just looks like a DOS screen. I tried reset and master reset, no go...any ideas?
  • Anonymous Oct 10, 2008
    i have the same prob!
  • 44 Answers
Did you try and redownload software?
Posted on Jan 12, 2008
Why is it that my Clearco HD9000 projector defaults to 1080i when connected to my SKY HD Satellite box, which is great but when connected to my Pansonic Blueray it defaults to 1080p resulting in lines down...
> 1080I
This is "interlaced" output -- the 1st horizontal line on the screen is painted,
then the 3rd, 5th, 7th, 9th, etc lines are painted, to the bottom of the screen,
then the 2nd, 4th, 6th, 8th, etc. lines are painted.
Your satellite box probably outputs both 720p and 1080i.
> 1080p
This paints the screen in order: 1st line, 2nd, 3rd, 4th, 5th, etc.
which some video-philes indicate produces a "better" picture,
i.e., smoother display of moving objects on the screen.
Your BluRay player probably outputs 1080p, because BluRay has been designed for High Definition displays.
So, check the manufacturer's web-site for the CLEARCO, to see if it supports 1080p mode.
Mar 09, 2011 | Computers & Internet
1996 gmc jimmy will not shift to 3rd gear
Hi, It may be in LIMP mode.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
Common failures on 4L60E, symptom any possible repair:
Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under-hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter :ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
If you can get the Jimmy for no more then $500.00 and the engine sounds good and body is good, you may want to invest in the repair of the jimmy. Also note that to have a close look at the fuel line along the frame on the drivers side just by the back doors, the line is know to corroded there on all the SUV's
Sep 19, 2010 | 1996 GMC Jimmy
Only runs in 1st and 2nd gear and reverse.
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Dec 14, 2009 | 2006 Hummer H3
4L 60E - 2001 k1500 will not shift into 3-4. Oil is not burn't and stifts great into1-2
  • No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
  • Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
  • No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : Shift A solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Check to see if your transmission is in the limp mode, which would only give you 2nd, 3rd and reverse gears. No 1st or 4th gear.
Nov 19, 2009 | 2003 GMC Sierra 1500
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Blackberry 7290 unlock proceedures
Hello.
I think I see your problem.
The 'mepd' must be uppercase. Hold the shift key down while typing in the MEPD.
Once you get into the area that shows what limitations are active or disabled, then you must use the Alt. Option key on the fare left third row of keys down. Holding the Alt. Options key, type MEP then release the Alt. Option key and press 2.
You should now be prompted to enter the unlock code. If not, start from where you had the last correct results. Also, If it will not work, back all the way out to the memo icon and try the keys you need to type to insure all of the keys are working and you are not fighting a temperamental key switch.
Good luck in your quest.
If you still need more help, just ask.
Oct 17, 2008 | RIM BlackBerry 7290
7290 problem
Here is the procedure to completely clear the device , You will have to reactivate the device on the network after doing this
1.In the handheld options, click Security.
2.Click the trackwheel.
3.Click Wipe Handheld.
4.Click Continue.
5.Type blackberry.
Mar 11, 2008 | RIM BlackBerry 7290
Slow access
Go to options, status and make sure you at least 4 mil bytes of file free memory.
Sep 22, 2007 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
103 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
