SOURCE: Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
This solution worked for me. By removing the 2 screws holding the filter in place I could turn the filter and push it back into the machine. I could feel a thick cord which felt more like electrical cable but, by feeling around the area where I judged the lock to be located on the inside, was able to locate the actual catch and release it. Thanks Chris72! This saved me a lot of money on a service call and much frustration at not being able to get to my clothes for several days - the earliest the repairer could come.
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
SOURCE: is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
SOURCE: Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
