Question about Bosch Toys
Hi, I got a used barbie tri-scooter and the handels are not straight so that makes the front wheel can't be staight either and my doughter have to keep them with angel that front weeland back wheels be in the same direction which make it hard to drve it. I don't know how to start to make it fix. I hope you understand what is the problem with the scooter and help me. ICAN"T FIND THIS ITEM IN YOUR CATEGORIES!!!! Thanks , Firoozeh Heiche
  • 274 Answers
SOURCE: Front wheel veering right (hard right)
You can take it to a bike shop.  They can re-align the wheel for you.
Posted on Nov 01, 2007
  • 48 Answers
SOURCE: The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
SOURCE: wheels have worn down
If you go on the Maclaren website, I know that if you are in the UK its how you do it. Then basically look for the repairs tab, then it will give you the option to search for your nearest stockist of these wheels. Beware you may need to travel a distance! Maclaren aren't the best when it comes to customer service, and they need to work on how to improve the back wheels..they do wear down way too fast!
Hope this helps - Failing that I found some on eBay?
Best of Luck
Lucy E - London x
Posted on Jan 29, 2009
  • 54 Answers
SOURCE: Vw passat 1.9 tdi 2001 squeaking noise from the front
Yes it could be the wheel bearing. After stopping, see if the wheel itself is hot to the touch (like burn your hand hot) if so, take it to the shop right away...unless you plan to change out the wheel bearings yourself.
Posted on Feb 23, 2009
SOURCE: Parts for the barbie cash register
I just called the number in the link above looking for the credit card for the Shop With Me Barbie Cash Register and they indicated to me that they have the price sheets available for that particular toy. I don't know if you have that particular cash register or a different one, but that set sells for $7.00.
Posted on Apr 09, 2009
How do I replace a tire on a pride maxima sc900v 3 wheel scooter?
Hi. Ring monster scooter parts the rear wheel assembly cost $132 dollars there is no mention on the front wheel assembly they might help U with more information 800-798-0325. ... Cheers
Sep 28, 2016 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Manual for quingo plus
hi, I have repaired loads (100+) of Quingo and they are standard with most of the scooter parts except the gearbox,,,four bearings on the axle ,so well made ....
normally they fitted a Rhino 110amp controller so how i can help ?
a nice scooter except when the front assisted wheels bend , very dangerous as they take the pressure off the front wheel causing it to go straight so beware...when turning ...
Apr 06, 2015 | Health & Beauty
How can I adjust my Pride mobility front wheel assembly?
There is a large nut under boot above the front wheel. Loosen that nut for limited adjustment but should be able to get it straight.
Aug 25, 2014 | Pride Health & Beauty
Does anyone know where I can find schematics for pride victory?
You need to adjust the tow in. There is adjustment underneath.
Aug 25, 2014 | Pride Mobility Victory 3 Wheel Electric...
Power wheels
If the wheels are bowed out it is usually caused by the steering linkage being damaged. Power Wheels vehicles have a long metal bar that runs between the two front wheels on the vehicle, on either end of the long bar is a plastic bracket. The bracket is riveted to the long bar and sometimes that can become loose or bent.
Remove the battery and flip the vehicle over, inspect the linkage and also the front axles to see if they are bent or damaged. If any parts are they need to be replaced, also make sure the tires themselves are not damaged.
Here is a link to the parts you will need for the repair.
Front Axle:
Axle Cap:
Let us know if you have any questions.
May 11, 2013 | Fisher Price Power Wheels Barbie Jammin'...
Front end left wheel is tipping inward (the top of the wheel leaning in towards the unit. I was told by the dealer that the wheel is tipped for turning purposes, he put a washer on but it is still. Should...
Hi Karen,if who carried out the job were qualified,it should be fine.But any wheel would have to sit even on the ground,for it to wear evenly.I hope this has been helpful,take care Colin.
Nov 03, 2011 | Pride Mobility Products Pride Legend XL -...
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
Where to find replacement wheel?
At any sporting goods store like Sport Authorities, Sport Chalet or Big Five.
Aug 18, 2010 | Dynacraft Barbie Aluminum Scooter
I own a 1984 Honda Elite scooter I can hold the front wheel with my legs and align the steering by twisting it. Now the front wheel just almost flops around as though it is disconnected from the steering...
wise thing to do,,dont ride it,,the nut on the handel bars gos into a wedge in the end of the forks nip up the nut and it should tighten up the bars dont srip the thred on this bolt as there very much like a push bike handel bars,,,and they work just the same way
Mar 13, 2010 | Honda CG 125 Titan ES Motorcycles
How to unfold the scooter
there should be a silver latch near the base that you hold to release the handle. The lever i think is by the front wheel on my daughters... hope this helps
Dec 14, 2009 | Dynacraft Barbie Aluminum Scooter
Toys Logo
27 people viewed this question
Top Bosch Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bosch Toy Expert? Answer questions, earn points and help others
