Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Proheat x2 = No Floor water output or Brushes rotating
This is the 'blue' model, purchased 2 years ago, only used to 'test' an area since, we came to use it yesterday and found that both the tools and floor suction work but there is no water outflow to the floor operation, my husband who tested it upon purchase also seemed to remember that the brushes rotate under power (not just pushing), the rubber band is not perished but the brushes are also not rotating. I am just off to clean the pipes as previously discussed on the problem 'string' and will update but can't see that clean pipes will affect the brush rotation!
chris321918
  • 32 Answers
SOURCE: My bissell proheat 2x (9200)
There are several things to look at. The brushes will not spin while the machine is in the upright position, the circut breaker could be tripped, As to the no suction problem, the problem that comes to mind is that the Red float "door" in the tank may have closed as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. But just in case this isn't a full solution. Here is a link to your owners manual: http://www.bissell.com/images/UserGuides/9200_908.pdf
Posted on Jan 24, 2009
  • 25 Answers
SOURCE: Since the last use of my new ProHeat X2 carpet
Check the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool mode). On the underside of this section is a small (about 1 inch square) red plastic piece with a little door on it. Flip open the door and you will probably find it is clogged. Clean it out and you should have full suction again.
Posted on Sep 22, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
ffuutr
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Brushes will not rotate on Bissell Proheat Select?
sssHi,
heatman101
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I am trying too use my Bissell Proheat 2X, but the brushes will not rotate. What is wrong?
1. Can you hear the electric motor in the base unit going?
2. You may have a broken drive belt.
Type the following link into your browser. It will bring up the user guide to the Model 9500p upright ProHeat 2x.
Sep 21, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell 9200 proheat X2 wont **** up water
heatman101
r
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes
I'm no expert...i'm just waiting on someone to answer my question....but the unit has to be on the floor with the handled released b4 the roller move.
Aug 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
222 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
