Question about Refrigerators
I have a Maytag MSD2641KES refrigerator. Where is the defrost heater located?
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
  • 358 Answers
SOURCE: Defrost Heater on Refrigerator
It's located on the freezer side.Take off all the shelves and the drawer and you see a panel with lots of screws atached to the back wall , take it out and you'll see the coil and the heaters atached to it ,one in the bottom of the coil and the other in the middle.
Posted on Apr 17, 2009
SOURCE: I need to replace the adaptive Defrost Control
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Posted on Nov 19, 2009
Testimonial: "great help"
Macmarkus
  • 2605 Answers
SOURCE: Where is the defrost module for a maytag
Hi, welcome to fixya.
If it is the actual component which control's the defrost cycle ( what was once referred to as a "defrost timer" ) it is located in the fridge section up under the plastic light and control covers.
For many modern fridges including yours, It is known as an "adaptive defrost control" and looks like this...ad5c9b2.jpg
If you are referring to the actual defrost heater and bi-metal/DTS, they are located in the freezer section behind the evaporator cover.
Hope that answer's your question. Let me know either way.
Thank's for visiting "fixya" today. Please take a moment and rate the info provided for you here.
macmarkus :)
Posted on Jun 14, 2010
  • 3287 Answers
SOURCE: How do I replace the defrost heater on a Maytag
1) Unplug the refrigerator. 2) Empty the contents of the freezer. 3) Loosen / remove as required mounting screws securing the ice maker. 4) Unplug the ice maker's wiring harness from the back of the freezer. 5) Remove the screws along the edge of the freezer compartment back plate. 6) Remove the back plate.
You should now see an ice or frost clogged coil and fin assembly, a heater clipped to the fins and a sensor attached to a portion of the aluminum cooling tube (these last two items will be visible only after defrosting). The last item - the "sensor" is really called a "defrost terminator". It is a thermally operated device - much like a thermostat. It is open or off at around 50 degrees and higher and closed or on below about 50 degrees. Defrost as needed, but do not do it by chipping away at the ice! Damage to the coil will be very costly to repair - better to use a blow dryer to quicken the process rather than tools and sharp objects for chipping.
Disconnect and remove the heater. Check the heater with an ohm meter to be sure it is faulty. Expect about 25 ohms resistance. If it is much more above this value it is suspect and should be replaced. The heater typically is not a high failure item, but they do fail. The defrost terminator or defrost timer assembly is more likely to the culprit.
Tools needed: small sockets or nut drivers, common straight & phillips screw drivers, maybe wire cutter / crimper, maybe an insulated **** splice for the size wire to be cut or other suitable wire connector.
I hope this helps & good luck!
Posted on Jun 18, 2010
How do i replace the heater on a maytag RSW22E0D side by side?
Place all frozen items that are inside the freezer now into a ice chest. Unplug the power cord from wall receptacle that goes to the refrigerator. Place a few towels inside the bottom section of freezer to absorb any water that overflows the freezer floor during manual defrost. Place a bucket of very hot water inside the freezer and close the doors. Give the freezer time to warm up and melt the ice behind the rear wall of the freezer. Click HERE RSW22EOD Freezer Parts Breakdown to view the freezer components. Remove item #20 in that photo to expose the=> 61001846 Defrost Heater Elements The 61001846 Defrost Heater Elements can be seen as item location 20 in this photo=> HERE It may be a good idea to change the 52085-29 Defrost Thermostat It's just easier to get to while replacing the defrost heater elements. I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jun 22, 2014 | Maytag MBB1956GES Bottom Freezer...
Maytag fridge RTT1900DAE - need instructions/diagram to access defrost heater, defrost timer, and defrost thermometer, so I can test them all. Haven't been able to find anything helpful using Internet...
defrost timer should be in the refrigerator side behind the temp control knob, defrost heater and thermostat should be located in the freezer compartment behind the cover plate for the fan. Just remove your shelves and you will see the screws holding the cover plate on, remove them and you will see the coils and fan. Thermostat / heater are at the bottom of the freezer coils
Sep 17, 2013 | Maytag Refrigerators
Where is the defrost module for a maytag refrigerator (model msd2756dew) located?
macmarkus :)
Jun 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer frosts up and will not defrost itself anymore. Do I need a new defrost timer and/or thermostat? If so, where is the timer/thermostat located in the refrigerator?
It could also have a bad defrost heater. The heater and defrost thermostat are located mounted on the evaporator coil and the timer is usually mounted in the control panel with the control thermostat or in the compressor compartment.
Aug 28, 2009 | Maytag Refrigerators
Freezer coil continues to ice up.
no you have to locate defrost timer to activate heater.if heater still doesnt come on check heater for continuity then defrost termination switch
Aug 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Defrost heater not turninh on
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Aug 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
Maytag firdge not cooling on the fridge side
In the fresh food compartment remove the two control knobs/dials by pulling them straight out remove the 1/4" hex head screw holding on the control box and damper housing its kind of hidden 1/2" deep or so right next to the vent that allows air into the fresh food section. once it is removed you will see a box with a screw and panel to remove the control is inside that box you'll figure it out from there.
Apr 01, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
