Question about Clarke Power Products Clarke 130EN Mig 110 Volt
Looking for schmetics on a Clark 130EN
Is there any way to check the transformer for humming. Is there any place to look for a schmetic on this welder.
    Guru:
  • 462 Answers
A volt check and a design voltage is required. A fuse on the line side of the transformer would be worthless on a welder (I believe) so a burned wire or control circuit to the transformer is most likely. You can ohm out the transformer and mathematically you can come to understand the workings of the windings. First remove 1 side of the wire feeding the transformer and check for main winding resistance. If you have some (not high like million ohms but probably in the thousands) then assume that part is ok then proceed to the secondary side from your ground to the terminals on the other side of the transformer feeding the stinger end. removing wires as needed. If this checks ok then the transformer is most lkikely ok and your control switch or the control board is at fault.
Some of the boards may or mat not have fuses so look for these as a sigh of troubel befroe persuing a replacement part.
Posted on Apr 26, 2009
    Problem Solver:
  • 19 Answers
This might help...
http://clarkeusa.com/manuals/we/WE6523.pdf
they arent great drawings but it might do the trick, you just have to listen to your welder to hear if it makes any funny noises, during welding and during rest. good luck i hope i helped
Posted on Apr 22, 2009
My dashboard cluster lights up but the gauges dont work, what are some possible problems?
A new circuit board , circuit board voltage regulator
look at the schmetics and see if there is a common ground or source of B+ that they all share, see what hind of shape its in.
Apr 07, 2010 | 1996 Pontiac Grand Am
Clark 130en does not feed well. Feeds great on 10
try checking the tension on the feed roller,you may have too much tension which in return will not allow the wire to feed right,check to make sure your feed roller is for the size of wire you are using,next check the tip size for the wire your using.
Mar 17, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Need schmetic for ge spacesaver model jvm1653wh01 need to replace upper door switch
remove micro switch and can be purchased locally electronics surplus or Radio Shack
Mar 13, 2010 | GE Microwave Ovens
Electrical- no fire @ plug honda crf 70 2006 year
run wire from one side bolt to other side and try again if it works coil is bad did you replace plug and check gap?
Jul 04, 2009 | 2005 Honda CRF 100 F
Gas or vacuum problem
You must get a manual for VT500c/e, what is your problem?
Mar 15, 2009 | 1984 Honda VT 500 C Shadow
43h71 service manual
What is proiblem with your set?
Oct 09, 2008 | Toshiba 43H71 43" Rear Projection...
Clarke Power Products Clarke 130EN Mig 110 Volt Logo
385 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
