Question about GE RM94930 Remote Control
Need the codes
There is a 3# code to program this remote i'm requesting this code and programing sequence
  • 934 Answers
SOURCE: need instruction sheet with codes to program jumbo remote control
Posted on Feb 10, 2008
SOURCE: how to program my rav 300 remote
go to to download complete manual for free good luck
Posted on Jun 24, 2008
  • 51 Answers
SOURCE: Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing
Posted on Nov 08, 2008
SOURCE: how do i program the ge universal remote, model rc24912-e
Posted on Dec 27, 2008
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
  • 33 Answers
SOURCE: Need Hitachi TV code(s) for GE Universal Remote #24912 - thanks!
here is the 2 links for the codes, they are pdf files. hope this helps
Posted on May 05, 2009
0 characters
1 Points
How do i link remote to tv and dvd?
Hi Damien,
Unless you have an 'intelligent' remote (e.g. Samsung), then you'll have to program either remote to sync with the other device. For example, if you want to use your original TV remote, then you'll find a program procedure and code in your TV manual (or online). There will be a remote button sequence you follow, including the input of the code that corresponds with your DVD model (e.g. Sony). If the remote takes the code, then it is actually programmed and should communicate with your DVD in a generic capacity. Sometimes your device remote has device-specific features that only its original remote would be able to access, so don't get rid of the DVD remote.
I've attached a link to Samsung's programming sequence -- yours would be different of course with a different mfg.
How To Program Your Samsung Universal Remote
Good luck.
Feb 26, 2015 | Remote Controls
My universal remote doesn't have code search how do I know how to program it
Your RCA universal remote has a CODE SEARCH button.
1. Turn on the device to be controlled.
2. Press the CODE SEARCH button and keep it depressed until the red indicator turns on, then release the button.
3. Press the button for the device you want to control, e.g., TV and release.
4. Press and release the ON-OFF (or POWER) button firmly and repeatedly (up to 200 times) until the device turns off
5. Press the ENTER button to program the code.
Oct 02, 2014 | RCA 4-Device Universal Remote
Want to set up Universal remote broke original remote
Universial Remotes come with an instruction booklet that will detail how to program your new remote with your audio/video devices.
There is a 4-5 digit code for television/dvd/vcrs that you need to input on the remote control via its programming sequence in order to use it with your tv/dvd player.
The programming is usually done by pressing and holding 2 buttons on the remote until you see a flashing light on the remotes LED then by inputting the necessary code.
Apr 30, 2011 | Remote Controls
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
Hi, i have the rm312x remote control but i've lost the usermanual... i need code for my samsung aa64-0007a and the sequence to program the control
OK, you can download the manual (free) for your remote here:
This download is a zipped file and contains both instructions and equipment codes. Although it refers to a "Chunghop" remote, they are the manufacturer. Your remote has a GE badge, but this IS your remote.
Most GE remotes have the same programming instructions and use the same codes. You can download the programming instructions and the remote codes (in PDF format) from this page:
I suggest trying the 4 digit codes first as the 3 digit codes are generally for old models.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | GE JASRM24912 Remote Control
Sequence to program one for all remote
I can help you with your URC-3021 Universal Remote Control.
The codes for Daewoo TVs are: 0451, 1661, 0092, 0672, & 0623.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 05, 2010 | One For All URC-3021 Remote Control
Programing remote
how to program the technika tr41r remote control
May 04, 2010 | One For All URC-4041 Remote Control
My remote somehow became cleared and I did not keep the instruction sheet. I have retreived the code but the instructions. Help please!!!
all you can do, is call the manufacturer and request another owner's manual, or google " rca 3-device remote owner's manual"
Sep 24, 2009 | RCA 3-Device Universal Remote
I lost my instruction manual and the code can you help me program
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Jan 04, 2009 | RCA 3-Device Universal Remote with...
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
GE RM94930 Remote Control Logo
699 people viewed this question
Top GE Remote Controls Experts
Peggy Cook
Peggy Cook
Level 1 Expert
Are you a GE Remote Control Expert? Answer questions, earn points and help others
