Question about ASUS Computers & Internet
Overclocking asus p4vp motherboard
Id like to overclock my asusp4vp motherboard but i cannot see any jumper on my board.
  • 3,267 Answers
If you do overclocking you might end up burning the RAM sticks or the Processor. If you would explain what do you aim to gain by overclocking, then I'll try and dig peeper into MY memory....sodeep
Posted on Apr 13, 2009
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
Installed Windows 7 - got an "overclocking error"
please clear the cmos by moving jumper pin next to the battery area on the motherboard, make power pulg is off before moving jumper to clear bios memory to default
Mar 07, 2011 | ASUS Computers & Internet
How to overclock gf7050vt-m
Hi mitchmodi,
I would not recommend overclocking that board or other compenant on that board. That board was not designed for overclocking. Changing the voltage and speeds of the CPU could create error or blue screen of deaths on you, as well damage the board itself.
Thanks
Mark
Dec 08, 2009 | ASUS P4GE-MX Motherboard
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Possible overclock
Overclocking is now set on bios.
Just change the multipliers for desired speed, but be careful
Jun 22, 2009 | Computers & Internet
Motherboard
My suggestion is to never overclock. This makes the machine burn hotter and kills the life of the cpu. I learned this the hard way. If your gaming save up the money and go to the motherboard site and upgrade to a better cpu with fan.
Jun 17, 2009 | ASUS P5PE-VM Motherboard
Rampage 2 extreme motherboard is it overclock friendly?
set the jumper properly!!! some of the motherboards there are free jumper set!!! it meeans it is defauts
Apr 26, 2009 | Computers & Internet
Does asus make a motherboard that u can overclock. have a asus p6t deluxe v2 motherboard...does the rampage 2 motherboard be overclocked without any problems?
Some motherboard manufacturers make there motherboards (MoBo) "Overclock-friendly", and yes Asus does make the motherboards that are in that category. If the one you currently have lack of that feature, you could get third party software but be carefull and read the instructions before you change anything. Besides, take into consideration that you have to have optimal cooling devices for your component such as air cooling or water cooling before you overclok anything in your computer, keep this in mind: overclocking=heat increase
Apr 26, 2009 | ASUS Computers & Internet
How to overclock my motherboard ?
there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
Apr 13, 2009 | Computers & Internet
Overclocking Failed K8S-MX
There should be a jumper to reset the CMOS, look in the manaul to locate it. And ya.
Jan 22, 2009 | ASUS K8S-MX Motherboard
Computers & Internet Logo
178 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
