Question about Nikon D200 Digital Camera
Nikon D200 images not sharp
I'm using a Nikon D200 with 17-55mm f2.8lens and the result I am getting is very poor. images are not sharp. They seem to be slightly out of focus and even certain parts of the photograph are less sharp than others. I've tried using another lens and the result is the same, so i'm guessing its not the lens. I've just cleaned the sensor with sensor swabs and eclipse lens cleaner. The results improved but still not 100%. Can anyone help???
  • 4 more comments
  • gmanduca Apr 13, 2009
    no I haven't dropped it. how do I find out if its the CCD thats to blame?? can it be replaced?? or can i calibrate the camera and lens?? i've also tried a 55-200mm lens on the D200 and on the D70S. Same result, D200 not sharp, D70S sharp
    yes i've cleaned the CCD twice and it hasn't helped. the colour still looks ok. lenses are clean too. i'm lost, don't know what else to try
    thanks for your help
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    pls send ur camera for focus issue to Nikon bcoz it is digitally calibrated u cant do it at home they have equipment to do this
  • Shoaib Rais
    blurry pics are result of dirty Lens or CCD u have cleaned it already
    CCD problem starts with Blurry pics and if u watch closely colors are also not real i mean red green or blue are not balanced when u see closely pls see and tell me
  • Shoaib Rais
    have u dropped it ?
    may be bcoz of 2 things
    BAD CCD
    CCD chip and lens assembly is not calibrated after a drop or a blow
    Problem Solver:
  • 20 Answers
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Posted on Jan 06, 2010
Nikon D200 has become nearly impossible to grab images
False low-battery warnings, focusing, and metering problems may be the result of poor contact between the body and certain lenses. Try removing your lens and thoroughly cleaning the contacts. I would recommend using a contact cleaner, but rubbing alcohol will also work. Remember that the whole ring needs to be cleaned. If that does not work, try scraping the battery contacts.
Feb 01, 2010 | Nikon D200 Body Only Digital Camera
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Apr 12, 2008 | Nikon D200 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cropping
You cannot crop images and save them on a D200. Thats what the Nikon Capture and Nikon PictureProject software are for. Here is the Cnet review link: http://webshots.com.com/digital-cameras/nikon-d200/4507-6501_7-31568586.html?tag=sub
You've made an excellent choice btw....
Jan 04, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D300 RAW images have alot of noise / artifaction
I have bought two Nikon D300 in the past ten days, the first camera had stuck pixels, 12 of them, red dots in every image. The second Nikon D300 is so noisey in every ISO other than 100... it is worthless to me at this point. Sharp as a tack, but so noisey, the sharpness is moot. I think I have a solution, but it will involve dumping a $164,000 Nikon equipment history over the past 30 years and embroidering new patches on my photo vest which read, CANON! The fact that I even have to consider such a move makes me nausious. Nikon has betrayed many of it's biggest fans, me being one of them. I don't know what happened at Nikon to allow them to fall so far behind Canon, who trailed Nikon for nearly 40 years, but SOMEBODY SHOULD BE FIRED!!!!
Dec 09, 2007 | Cameras
NikonD200
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Feb 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera Logo
1,057 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
