Question about Hotpoint WMA48 Front Load Washer
Water is leaking from the door especially when on fast spin
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. gets worse when it goes on to the spin cycle. Please help
  • 118 Answers
You need to get a new rubber door seal u can get it from this website http://www.4hotpoint.co.uk/cgi-bin/home.pl?gclid=CMKHz4OM05wCFZMU4wod5HwDKw to replace it you take the clip off the front of the washer the peal off the seal off the frame and the do the same off the drum then but the new one on.hope this helps.
Posted on Sep 02, 2009
I have a wma 10 which is a couple of years old. The door seal now leaks when the machine goes onto a spin? Is there anything that you can suggest?
Sounds like there is too much water left in the drum as it goes into the spin cycle, and the centrifugal force of the drum spinning is forcing the wate past the door seal probably, needs the filter cleaning, or the door seal itself may require replacing.
Aug 04, 2010 | Hotpoint First Edition WMA12 Front Load...
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
Jun 11, 2010 | Hotpoint WMA48 Front Load Washer
I have a WMA 48 and it keeps tripping the electric when i put a wash cycle on, although it will complete spin cycle
there is a ground leak or pos net leak in the main motor it needs to be looked at by a service agent very dangerous problem dont use it till fixed
Apr 27, 2010 | Hotpoint WMA48 Front Load Washer
Hotpoint wma 10, rus through cycle till it starts the fast spin it does a few revs, shakes alot, it then trips to the end and prog end light comes on together with the door lock light, it must be unplugged...
Just a thought but you never tampered with the water level on the pressure switch did you? This would give off similar faults. It could be the pressure switch itself or the chamber is partially blocked it could be a broken or loose tacho wire on the motor. Or it could be a fault on the main control board.
Mar 04, 2010 | Hotpoint First Edition FEW10P Front Load...
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Spin leak
The filter is located at the back of the machine.
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Goes straigt to spin
TRY CHECKING THE BOARD ON THIS MACHINE ESPECIALLY THE MOTOR CONNECTION. WHAT YOU WILL AHVE TO DO IS PUT THE DIAL IN TO THE OFF POSITION ( ONLY AS GUIDE ) THEN DISMATLE THE BOARD FROM THE FRONT FACIA. HAVE A GOOD LOOK AT THE MOTOR PLUG CONNECTION SECTION OF THE BOARD CHECK TO SEE IF THERE ARE ANY TRACKS THAT HAVE BLOWN. I RECONDTION WMA ALL DAY EVERYDAY AND I HAVE HAD THIS PROBLEM BEFORE ONCE AND AM THINKING YEH THAT WAS THE PROBLEM. OR IT COULD BE THE TACO ON THE END OF THE MOTOR BUT THIS IS VERY RARE FOR HOTPOINT WMA UNLIKE THE HOOVER MACHINES.
Aug 21, 2006 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
97 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
