Question about Razor E100 Electric Scooter
Why is my razor e100 red electric scooter going so slow?
Why is my razor e100 red electric scooter going so slow all of a sudden it was going really fast when i first got it now it's like a tortoise?
  • 4 more comments
  • fplqnewc
    fplqnewc May 11, 2010
    Have you been running the battery down all the way before you put it back on charge? This is recommended. You might also check for a flat tire.
    You don't want to keep putting it on the charger all the time even after just a little use, as this will degrade the battery.
  • Anonymous Mar 14, 2014
    My razor pocket mod electric scooters charger got wet what should I do
    ive lost the charger to my razor electric scooter anything i can use instead
  • Anonymous Mar 28, 2014
    How to fix the reset bottom on a razor electric scooter espark
    After charging my razor espark electric scooter doesn't run
  • daring girl 360
    daring girl 360 Apr 29, 2014
    me too
  • 3 Answers
Your scooter is dying the slow death that all Razor scooter owners are suffering. See my related post on this. Anyway, here's the deal..
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Posted on May 11, 2009
How to make a chistmas wreath>
Posted on Nov 30, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 31 Answers
Razor E100 electric scooters
I would like to have the instructions to the game of Mad Dash three minutes across America.
Feb 16, 2014 | Razor E100 Electric Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
Oct 21, 2013 | Razor E100 Electric Scooter
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Dec 30, 2010 | Razor E100 Electric Scooters Red
Hi i have a razor e100 today at a yard sale and brought it home and plugged it in and the green light turned on and i plgged it in to the scooter and the light tuned green so i pulled the plug out of the...
There are a few components to check when diagnosing electric scooter issues.
1. Batteries
2. Wiring
3. Controller
4. Throttle Assembly
5. Fuses
Once you inspect all of these for damage, you can test your motor and batteries, by bypassing the controller, and directly hooking the batteries to the motor. If the motor spins very fast, then you have good batteries, and a good motor. The controller will need to be replaced. If your motor spins slowly, you could require new batteries or Controller, or battery, depending on the results.
You can find replacement parts and service locator here.
urbanscooters.com/partsforscooters
Oct 02, 2010 | Razor E100 Electric Scooters Red
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
Charges and light comes and sounds like it engages but does not move
in order for the scooter to go you must already be walking with the scooter. so hold down the throttle and start to push (kick) the scooter.
Jan 31, 2010 | Razor E100 Electric Scooters Red
Razor E100 Electric Scooter Logo
4,330 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
