Question about Dryers
How to test heating element
My condenser dryer was not heating. inspection found burnt out contact at heating element. should I just replace the contact? How should I test the element - just check resistance???
thanks
  • 490 Answers
Check resistance is correct
Posted on Apr 13, 2009
Dryer has lost heat.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore 700 6972 Dryer
Stopped heating
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore Dryers
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
No heat
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 24, 2010 | Maytag MDE2400A Electric Dryer
The dryer is not heating to dry the cloths.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Dryers
My dryer is working but not heating
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Kenmore Elite HE4 Electric Dryer
Quit heating
Hi
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not start
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 19, 2010 | Dryers
Not heating
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Post back is more help is needed. Hope this helps...
Daniel
Sep 03, 2010 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
