Question about Riso RZ310 Duplicator
T20-414 RISO Printer : T20-414 Error Code is ''Flow Sensor Error'' 1. Open Rear Cover 2. Elevator Motor Check 3. Elevator Sensor Check 4. Drawer Sensor Check and PM!!!
  • Jeffrey Dunn May 11, 2010
    Is this a question?
    New Friend:
  • 34 Answers
Check the paper ejection unit that is a T20 code T02 code would be a standard tray lift issue.414 is not listed in the book for eather code
Posted on Jul 17, 2010
Kodak I1X09 fault code
I1X09 One Line Description: INSERTER SUPPLY 3 stalled when it was moving down Error Type: Soft Shutdown Error Description: If the ELEVATOR STEPPER MOTOR uses more than 130% of the maximum number of steps to move the PLATFORM of INSERTER SUPPLY 3 down to the expected position, the INSERTER SUPPLY CONTROL BOARD determines that the PLATFORM has stalled. An I1X09 error code is recorded in the error table and you must either use another INSERTER SUPPLY or press OK on the OCI to clear it. Theory guide: I1INSER1 Possible Causes:
1 The input to LOGIC and CONTROL from the DOWN LIMIT SWITCH is not correct. 2 The input to LOGIC and CONTROL from the PAPER FED SENSOR is not correct. 3 Mechanical binds in the ELEVATOR DRIVE SYSTEM 4 The input to LOGIC and CONTROL is not correct. 5 The FLAT CABLE is damaged. 6 Circuit for the ELEVATOR STEPPER MOTOR is not operating.
Nov 20, 2013 | Kodak Digimaster Ex110, Same As Canon Ir...
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
Riso rz220 ui error code P02-405
Error P02-405 means: The upper-limit sensor does not go ON within 12 seconds after the elevator motor operates in the raising direction.
Jan 20, 2011 | Riso RZ220 Duplicator
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
This code indicates an elevator motor Ascent/Descent Failure. Most commonly this is caused by one or more of the trays in your finisher not being fully inserted into it's "slot". Check the output bin trays at the far left side of your machine on the finisher. Be absolutely sure they are fully installed into their holders. Then turn off then back on the MAIN power switch in order to reset the code. Watch the bins. They should raise and lower and the code should be gone. If it comes right back and the bins are where they are suppose to be then you have another issue with the sensors or the elevator motor and will need service.
Most everytime I see this code it is always the trays are not all the way in.
Here is the info from the service manual in case your are the techy type.
Good Luck and Thank You for using Fixya. We are having a contest this month for customer testimonials. If I have helped you with your free question today please take a moment to leave a testimonial.
10.2.1 C1183: Elevator Motor Ascent/Descent Drive Failure
Code Description Detection Timing
Relevant Electrical Parts
Elevator Motor (M11-FN)
Elevator Tray Home Position Sensor (PC3-FN)
Elevator Tray Lower Limit Sensor (PC14-FN)
Top Face Detection Sensor (PC15-FN)
Elevator Board (PWB-B FN)
Main Control Board (PWB-A FN)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical Component)
Check the M11-FN connector for proper
connection and correct as necessary.
Check M11-FN for proper drive coupling
If OT-601 is connected, check the connector
for proper connection, and correct
as necessary.
Check the installation position of the
OT-601 tray, and correct as necessary.
5
Check the setting of the adjusting plate
for the Exit Tray detection position and
6 M11-FN operation check PWB-A FN PJ7A FN-1 to 2 FS-508 G-7
7 PC3-FN I/O check PWB-A FN PJ12A FN-2 (ON) FS-508 G-4
8 PC14-FN I/O check PWB-B FN PJ2B FN-3 (ON) FS-508 H-6
9 PC15-FN I/O check PWB-B FN PJ2B FN-6 (ON) FS-508 H-6
10 Change PWB-B FN - -
11 Change PWB-A FN
Oct 07, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Riso 3700 - Error Code G064
1 Power  swich off/on
2 Open and close front cover twise
Mar 22, 2009 | Office Equipment & Supplies
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
250 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
