Question about ASUS X51L-X2 15.4in Core 2 DUO 2.0GHz/ 2GB/ 250GB/ DVDRW/ Wvb Notebook Computer
Problem regarding dvd rom drive, i try everything i knowe but problem is i cant even burn a simple data on it, i already try all the solution
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    have u tried cleaning the lens
    try it
    open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is your drive a DVD ROM drive or a combo DVD ROM & CD R/W drive?
MY PC has sony DVD-ROM DDU1615 that I can't record my videos onto a dvd
you cant burn a disk with a dvd rom
you will need both a dvd rw unit and a dvd rw disk to burn any video to a disk if you have both of these the burning program might not support video burning or you might not have selected the right option there are lots of free burning software programs that can burn videos to a disk you might have to burn it as an ISO image
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Jul 21, 2011 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Can i burn dvds on my 2350 dell dimension computer if not what do i need
well if u have a dvd burner or a dvd writer installed on ur computer
then u will need to install softwares like NERO or ROXIO on ur computer
first chk, i thnk it mite be already installed on ur computer.
use them and u will be able to burn DVD's
Nov 02, 2009 | Dell Dimension 2350 PC Desktop
DVD ROM can play CD, but not DVD
try with next dvd which is burnt in less than 16x speed then check what happens.
Jun 02, 2009 | ASUS (E616P2) Internal DVD Drive
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
I HAVE A IBM THINKPAD T 30
Thinkpad T30 are usually supplied with the following optical drives, CD ROM, CD R/W, and Combo DVD ROM with CD R/W.
You most likely have the Combo drive, therefore you can play DVD and CD disks plus burning music and data onto CD-R and CD+R discs.
You need CD burning software such as Roxio Easy CD Creator or Nero. Both these programs are excellent and easy to use.
Jan 21, 2009 | IBM ThinkPad T30 2366 Notebook
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
try downloading www.slysoft.com thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Aug 21, 2006 | Samsung (SD-612) Internal DVD Drive
ASUS X51L-X2 15.4in Core 2 DUO 2.0GHz/ 2GB/ 250GB/ DVDRW/ Wvb Notebook Computer  Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
