Question about Belling SGE12X Front Load Washer / Dryer
Broken Door Handle on Belling SGE12X - soleniod version?
HI,
The door handle on our washer dryer has broken (gone very loose) and will not open. Ive taken the top off the machine to see if i can open it from the inside and i cannot seem to find any lever or switch to open it. All i can see is a long oblong plastic casing that i can only assume is the soleniod as its got wires coming out of it. Any ideas how i operate the release mechanism?
Alan
2 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Posted on Oct 25, 2008
Door handle broken off. How do i open the door?
You don't say if it's in or outside handle, either way:
  1. go around the car and open the good door
  2. then you can unlock the broken door
  3. use the inside handle, if gone, use outside to open door,
  4. go buy a new handle and replace it
MDS
Mar 28, 2016 | Cars & Trucks
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Mar 21, 2009 | 1991 Honda Accord
Broken plastic door handle
Depends what you mean by the "handle". The outer door ring is listed as a spare part 112100592, and behind it is the "handle"
112300530.
In view of the age of this model, spares may be hard to find, so keep an eye on eBay for a used door or door assembly or whichever of the part numbers above is required. Good luck.
Jan 11, 2018 | Splendide 2100 Vented Washer-Dryer
Belling SGE12X broken door handlw
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
Spin cycle complete; door refuses to open
check if the water has completely emptied - maybe the filter needs clearing.
otherwise. switch off mains. take top off. feel down the front of the machine to the door lock. you can usually find the peg and operate it with thumb nail but difficult
i assume you have'nt broken the door handle
Sep 18, 2008 | Belling SGE12X Front Load Washer / Dryer
Belling SGE12X Front Load Washer / Dryer Logo
47 people viewed this question
Top Belling Washing Machines Experts
shaun taylor
vince
Kolbrun...
Are you a Belling Washing Machine Expert? Answer questions, earn points and help others
