Question about Alpine TDA-7563 Cassette Player
Alpine cda7969r display problem
Hi i have alpine head unit and it all light up and plays apart from the lcd display, this does not light up at all. all the wires are connected and fuses ok. any ideas?
  • Anonymous Dec 14, 2008
    Mine is an Alpine TDA-7563 with the same problem.
Hi trinder,
I fixed my Alpine TDA-7563 with the same problem. My display was completely blank everything else worked. After checking that the LCD display is getting power and everything else in the face that I can think of, I thought maybe the rubber LCD contacts were squeezed down or something and not making proper contact, so I just pushed it back onto the board and pressed.
This was at night, so I had an external lamp and noticed to my delight that the display was in fact working, nothing is wrong with it.
I am embarrased to say that as a technician I forgot that an LCD display needs a backlight, duh.
So a simple connectivity test on the 2 lamps shows that they are both blown.
I have to source them at my local electronics store, I measured the power supply to them as 12Volts, so it is just a matter of getting ones with the right dimensions and bright enough.
Hope you have the same problem, then it will be an easy fix for you.
Good luck,
Ramesh
Posted on Dec 14, 2008
SOURCE:
I cant watch video on the alpine iva d100
Sometimes they have a setting on video head units that only allows you to play video when the parking brake is on, try that and see if it works.
Nov 12, 2009 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
Alpine CDA-9835 Head Unit
it may have a connection problem(flexible strip) to the PCB that has dislodged, or the display itself has developed a problem. Couple of questions, is it entire characters that are missing, or parts of same. Is the unit still operating normally?
Hit me back here and we shall get to the bottom of your problem.:)
regards
Graeme
Feb 14, 2008 | Alpine CDA-9835R CD Player
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work correctly.in a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
My alpine 9965E LCD display keeps on turning to black after a few seconds, but the head unit works. If i increase the volume, go to the next track, the LCD display pops out again
you have turned on the "black-out" feature to get it back look for a little button over the volume knob with either "dispay" or "blackout" on it. Press and hold it and you will hear a beep to let you know you changed it. Why Alpine put that feature in the head units is to confuse and comfound drivers is my guess.
Aug 02, 2009 | Car Audio & Video
Display read "disc error" then "no magazine"
Most likely there is a CD jammed in transit between the player mechanism and the magazine. This is a common problem. You will have to remove the unit and disassemble it sufficiently to get the CD back in the magazine and, in turn, allow the magazine to be removed.
Jan 28, 2018 | Alpine Car Audio & Video
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
How do I get the clock to always display on my head unit Alpine 9884 cda
Look for "TITLE" button on the right hand side of the display.
press TITLE repeatedly until the time is displayed.
set time.
when power is OFF but iginition is ON press TITLE to display the time.
i hope this solution helps .
Jul 11, 2008 | Alpine CDA-9856 CD Player
I have a AIWA XR-MDS7 EZ sup mini stero unit, the lcd display is dead although the unit works I cannot tell what disc is playing or track number. Also I cant tell what radio station is playing. Everything...
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Dan
Apr 11, 2008 | Audio Players & Recorders
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Alpine Ipod/Stereo Error 1 message
my alpine cda 9856 only displays that message when my ipod dies. so your ipod pobably dies then the head unit recharges it enough in the time your resetting it that it can play again. :)
Nov 26, 2006 | Alpine CDA-9857 CD Player
Car Audio & Video Logo
788 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
