Question about APC Back-UPS® CS 500 UPS System
Ups is not glow any indication, just give buzzer sound , APC make 2000va RS model kindly tell me what i can do to repair it.
  • 3 Answers
It look like dead battery. Try to connect carefully new (or allmost new) battery with 24v lamp in (+) wire. If UPS alive - you'll see only small momentary sparcle. After this - connect battery as usual and try to turn system on. Be carefull! If lamp lit in full power - it means a serious internal problem. Best solution - look for qualified serviceman. (maybe yoir system needs reprpogramming).
Posted on Apr 14, 2009
UPS not working
check the batteries are still good and not expanded and split the sides or ends
Aug 17, 2016 | APC Smart-UPS RT 2000VA UPS System
Apc smart ups rt 10000 internal fault, what will cause it?
if you can give me the source code I can tell you. the code is going to be in the form of zero's and one's
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
APC RS 1500 82v output
Many UPS Systems have a squared wave when working on batteries. Cheap multimeters do not give the correct measure on squared waves. Connect a 100 watts resistive lamp to the output of the UPS, if the light is almost the same when UPS is working on batteries, everythinf is fine.
Dec 23, 2013 | APC BX 1500 Back-UPS XS 1500 (APNBX1500)...
Having UPS Model No. BR 1500 in time of opening UPS shows over lode without giving any lode. Battery is new . can you tell me the solution.
Try to reduce your load. in a overload condition the UPS can not tell you what the load is if it has more then the 1500VA your UPS can not put out more then 1000 watts. Battery has nothing to do with the load.
Sep 09, 2011 | APC Back-UPS RS BR1500-IN (BR1500-IN) UPS...
My APC BR1500LCDI has RJ-45 data port, how can I communicate with it. I lost the cable data provided by vendor.
The APC UPS communicates with the computer using a data cable that has a RJ45 connector at the APC and a USB connector at the computer. This data cable and communication software CD is available from APC.
Go to this APC WEB site for a manual for your model UPS.
http://www.apcmedia.com/salestools/KBOK-7A3TGR_R0_EN.pdf
Apr 09, 2011 | APC BACKUPS RS 1500VA LCD 230V...
Even when it was brand new, my computer loses power even if it is not black out and my Back-UPS RS 500 blinking and cotinously beeping, and always my computer did not properly shut down. please help me to...
You need to replace the battery. Go to APC site and order the battery for your model. http://www.apc.com/resource/include/techspec_index.cfm?base_sku=br500i go to about the middle of the page, there are two models for replacement batteries. If you're not sure which one, call APCs customer support. 800-555-2725 I don't know what the shelf life is for your model but the battery usually last 3 yrs or so. Your battery is probably dead now.
Mar 02, 2011 | APC Back-UPS RS 500VA (BR500I) UPS System
I just replace the battery in my APC RS 900 unit because the red indicating light was telling me to do so. I installed the new battery and the red indicating light is still telling me to replace the...
Sorry to read about your problem, I hope this helps you out.
let it charge 24 hours, and see if it works
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | APC Back-UPS RS 800VA UPS System
With out load condition over load indication led glowing
It is the problem of your ups board . Give it to a authorised service center.
Dec 03, 2010 | APC Smart-UPS 1000VA UPS System
It's an older unit that i just tried. When i plug
Try installing the software that is included with the unit. If you didn't get the software, I believe you can download it for free from APC's website. The software will typically give you the status of the batteries and let you know if you need to replace them. If you can't get the software, take the batteries out (keep note of the wiring configuration) and test each battery using a DC voltmeter. The batteries should read around 13.5 volts DC. If they are around or below 11.5v DC, it's time for new batteries. This model, if its the black 110v version, requires the RBC32 which can be found at: http://www.batteryinternational.com/apc-rbc32--f2.html
Good luck and I hope I could help.
Jun 27, 2009 | APC Back-UPS RS Battery Backup (apw...
APC Back-UPS® CS 500 UPS System Logo
174 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
