Question about Refrigerators
How can I remove condenser tray to clean it?
Some milk leaked in the fridge and got into the condenser tray, I have got most of it out but can't get it all out as some is solid and now very smelly. I would appreciate any advice. Thanks
    Genius:
  • 1,122 Answers
Try using a hair dryer to melt the solids then clean the rest out,do you have a shop vac?-mike
Posted on Apr 13, 2009
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Can't clean out spilled (and now sour) milk spill
Hi, I'm not familiar with these fridges, but is it possible to access it from the back, underneath the evaporator tray? It could even be that the milk has gone down the drain hole and into the evaporator tray itself. Its a small flat plastic tray that has raised sides, and will probably have water in in, sits just above the motor
Dec 27, 2013 | Viking Refrigerators
Water leaking into fridge
Drain system is most likely clogged. The top of the frig is a tray that collects condensation. This runs down a tube down the back of the frig. Remove the tray, clean exit hole and check to see if drain tubing is clogged. Fairly easy to do, just pay attention to what order you take things off and just reverse the order to put back together
Mar 27, 2012 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
I have a Haier HRD-211 HP5 direct cool fridge. Last couple of days the air around the fridge is smelling like spoiled or sour milk - no smell inside or on the body of the refrigerator and cooling is fine...
Check the defrost water evaporator tray located inside the bottom grille. You probably will find a disgusting mess. Remove the tray and scrub it clean to resolve the problem. While you are cleaning up, check the tube that directs defrost water into the tray. It may be clogged.
Jul 02, 2017 | Haier Refrigerators
Leaking water from back on to floor
This could be that the drain tank at thebottom of the fridge is overflowing. Normally the drain water will evaporate off with the heat from the compressor but if possible it is good to clean and drain the collecting tray in the bottom of the fridge. You must have access to the backside of the fridge and remove the tray which is normally a pulllout. Drain , clean and put it back-- slide it in. Hope you do thei. Also make sure that the freezer setings are normal and not set high. During cold season this can condense more water to overflow the drain. Hope you try., Good day
Aug 10, 2010 | Refrigerators
Refrigerator is leaking from the bottom
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Good luck........
Aug 01, 2010 | Jenn-Air JCD2295HES Side by Side...
Milk which was spilled in the fridge has dripped into the drip tray behind the fridge and has created the most awful smell. Can the tray be removed for cleaning and if so how?
Yes, usually the tray can be removed for cleaning. You will have to pull the fridge out, unplug power, remove the rear access cover. Then you should see the evaporator / condensate tray and how to remove it.
Jun 22, 2010 | Refrigerators
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Fridge door
Have you cleaned the condenser in the eight years? If not it is due time. Some are located in back of the toe plate under the door. Others are located in back behind a removable panel. Be sure to reinstall the panel after cleaning as it is necessary for proper air circulation for the system.
May 26, 2008 | Whirlpool Gold® GC5SHEXNQ
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
