Question about Dishwashers
HI THERE WE HAVE UST BOUGHT A SECOND HAND LG DISHWASHER AND IT DIDN'T COME WITH A TOP OR LID AND IT DOESN'T LOOK GOOD. WE WERE WONDERING IF WE COULD PURCHASE EITHER A SECOND HAND ONE OR NEW ON? THANKS HOPE YOU CAM HELP US. SYLVIA
  • 490 Answers
Sylvia I am just guessing but I believe this is an under counter dishwasher and if that's the case it does not have a top you will have to mount it under the counter top
Posted on Apr 13, 2009
Lg dishwasher soap dispenser does not open during wash cycle
It is usually due to a lid spring problem or the solenoid operating the lid is faulty. In any case you need to replace the whole dispenser assembly. It looks like this (item K001) in this assembly chart.
http://www.appliancepartspros.com/section-4-parts-for-lg-ldf8812st-asteeus.html
To save hassles it might be worth switching to the dishwasher tablets instead of the powder. You simply drop the tablet in cutlery basket. A good brand like Finish should do you wonders. Might seem a bit expensive per wash but you extend the life of the dishwasher due to its cleaning efficiency.
Apr 21, 2014 | LG LDF8812 Stainless Steel Built-in...
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
MY LG DISHWASHER AND DRYER ARE DUDS
Hello,Sounds like a mechanical obstruction somewhere :->. Possible bad rollers or idler pulley. This could have snapped belt. Need to removed front door panel and lid to get at it. Open the door and rotate the inside drum by hand and see if it moves freely. If it does, you may rollers are probably good. Turn on power and listen for the motor turning on. If you hear a low hum then possible idler pulley or belt issue.LE error on DW - no quick fix here. I heard of wiring issues on the LG's, broken wires, that go from the control panel down to the motor/sensors/etc that result in this error code. I'm not up to speed on the LG dishwashers yet so maybe someone else can contribute.Rich
Apr 28, 2010 | LG DLE5955 Dryer
Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
Feb 26, 2010 | LG Dishwashers
Hi my dvd burner doesn't recognize my virgin disks
Sound like your cable that connects your burner to the motherboard. Try another cable, if you want to try another trouble shoot item, try connecting it behind the hard drive. Before you do set the jumper setting to slave on the burner and hook it up. That will help you to elimate a channel.
Nov 29, 2009 | LG Computers & Internet
LG6810 Dishwasher
Here is one source:
http://lge.andrewselectronics.com/lookup.aspx
I have provided the LG part numbers for the parts you are requesting. The vendor may need to convert those numbers to their own system.
Third item on the list should be: BRACKET, MOUNTING WITH SCREWS KIT --> LG part description and number: "ACCESSORY ASSEMBLY" 5001DD4001A
The lower cover assembly for Stainless part number is: 3551DD2001C To maintain quiet operation, recommend you order the "Lower Felt" part number 4766DD2004A
Good Luck!
Apr 06, 2009 | LG LDF6810 Built-in Dishwasher
Trying to program my dvd player with my lg tv remote
Turn on dvd player by hand using your lg tv control push set up dvd plus code.pointing for 15 seconds.
Nov 19, 2008 | LG 32LC7D Television
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
