Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Frigidaire Pure Source 2 water filter will not install
I have a Frigidaire side-by-side, I purchase a new Pure Source water filter and installed it. When I ran the water dispenser to prime the filter, the filter unit popped out. I pushed it back in, and it popped out again as soon as I pushed the water dispenser lever.
Now, it will not even stay in regardless of the water dispenser lever being pushed in or not.
I remember having the same problem when I installed the last filter, but can't remember what the rep. at Lowe's told me to do about it. Any help is appreciated.
  • Gina Sekhar Oct 23, 2013
    I have the same problem. I called Electrolux and they said they don't make the old filters anymore. They sent me instructions to install the new ones. i will try to upload the instructions
  • 93 Answers
SOURCE: Frigidaire pure source plus refridgater
There are a number of things that can cause both the ice and water in the door to stop working. There are two control boards that sit behind the buttons on the dispenser. Either one of them may have failed.
There are several different types of dispensor controls on this refrigerator. You need to download the Factory Repair Manual for your fridge. It will tell you how to remove the dispensor cover and diagnos each board so you know exactly which one to replace. The Repair Manual will be the best source for you at this point.
Posted on Jan 09, 2009
  • 190 Answers
SOURCE: The freezer side is NOT freezing, but the
Dear customer,
               We recommend you to do the follwoing checks
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak
Click on the highlighted words to know the steps necessary. Thank you..
Posted on May 07, 2009
  • 100 Answers
SOURCE: water filter problem
sometimes the bracket that you mount the filter to is damaged and needs to be replaced do you still have ice production ?
Posted on Aug 10, 2009
  • 998 Answers
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
SOURCE: Frigidaire Pure Source 2 water filter keeps popping out.
PRESS HARD when pushing the filter in, you'll hear the "Click", I have this fridge.
Posted on Aug 23, 2009
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ... > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
What problems have you encountered with newly designed Pure Source 2 water filter
I spoke with Frigidaire's Customer Service [(706)860-4110] and they said that the filter was redesigned. A customer needs to get a "service flash" number from the customer service representative. The rep will also provide you with local repair companies who will use the service flash number in order to get reimbursed by Frigidaire for fixing/updating the customer's refrigerator... at no charge to the customer.
Jun 08, 2013 | Frigidaire 1029438 Frigidaire Pure Source...
Where do I find the filter that needs to be changed
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
Hope this helps
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Pure Source Water Filter inside the refrig. is overflowing
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Dec 23, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaks into cabinet fron filter
You need a new filter housing to stop this from happening. You can repair this yourself and save a ton of money!!
Just contact us at:
from 7 AM until 7 PM CST with your brand and model number and we will get the correct part out to you asap. We also provide part removal/installation instructions for you when you get your parts through us.
We hope to hear from you soon and we hope you have a terrific New Year! Thanks, Ella
Jan 08, 2010 | Refrigerators
Replaced leaking filter but still leaking
Where is it leaking?, at the filter?, at the hook-ups on the filter?
Aug 22, 2009 | Frigidaire FRS23R4A Side by Side...
Water leaks from the pure source filter
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
My parents frig had the same problem. The steel tabs that hold the filter in place are very small and frail. Heres what I did to solve the problem, at least temporarily. While firmly holding the filter release button, gently bend the tabs together using an extra long pair of curved needle nose pliers.
Apr 15, 2009 | Refrigerators
The water and ice tases and smells bad. New coil and filter.
Replace the water supply line with plastic tubing or copper. Do not use the braided metal or vinyl line as they will cause an odor problem.
Feb 16, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
300 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
