What is sequence of files loaded into memory at the time of windows xp booting. What is the use of ''system volume information'' directory present in every drive
  • 432 Answers
If you boot into safe mode of windows xp it will show you what is being loaded and in what order ( too many too remember )
as for system volume information.
This is used for when you use system restore as far as i am aware.
Posted on Apr 13, 2009
Every time I start my laptop there is always appear two massage form and this is the problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows...
Hope you had deleted some files that relate to your system files.
Try to repair your system by Inserting your Windows XP Service Pack2. in your CD/DVD ROM and boot it again.
And if it's not working than you must format your system. And installed it. Here are the procedure to repair/install for reference. Thanks for Using FixYa All the Best!
Jul 28, 2011 | Microsoft Windows XP Professional With...
I was lost my motherboard drivers. Plz send information. this is my system configuration. OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 2 Build 2600 OS Manufacturer Microsoft...
go to the manufacturers website and download the drive for your mobo, if your internet doesnt work you may have to download them on another computer burn them to disc
Mar 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
What happens if we delete hidden directory system volume informat
Hidden directories most often serve to hide important operating system-related files and user preferences. This is mostly to protect the files. But malicious programs (malware, viruses, trojans) can also use this functionality to hide their presence.
The System Volume Information folder is a hidden system folder that the System Restore tool uses to store its information and restore points. System Volume Information (SVI) is the name of the data store where Windows XP and Windows Vista keeps its System Restore files and registration databases. System Restore not only saves copies of critical system files, it also performs automated registry hive backup.
There is one SVI folder per drive being monitored by System Restore. You can not view/access the SVI folder by default but there is a way to make them visible. You might need to gain access to this folder for troubleshooting purposes.
Basically, if you delete the System Volume Information folder, you will no longer have the files and data needed to restore your system to a previous state. For example, if Windows crashes or is stuck in a continuous boot cycle, you can use System Restore to restore your system to a previous "healthy" state. However, if there are no files or registry backups available, this tool is then no longer available to you. Also, if you ever decided to use System Restore, you would need to re-create the foler in the same path so that the system files can be stored there again.
Hopefully, you backup your system and keep good backups often...
Apr 13, 2009 | Microsoft Computers & Internet
Cpu usage nearly 100%
check in your task manager whats the service which is using your cpu usage and let me know
Mar 24, 2009 | Intel DG31PR Motherboard
After installing windows xp professional audio or sound is missin
I HAVE DELL COMPUTER, INSTALLED WINDOWS XP BUT NO SOUND PLS SOLVE IT
Mar 16, 2009 | Computers & Internet
Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Nov 11, 2008 | Computers & Internet
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Memory dump
Make sure your computer meets the minimum system requirements for running Windows XP if this is an upgrade - I had a computer that technically met the requirements, but boy did it run slow after I upgraded from Windows ME to Windows XP. If your hard drive contains no programs, information that you can live without, then you can completely reformat the hard drive and start over from scratch. If it does contain important programs, burn them to CD or DVD - and make sure that your computer can read the files after you are done burning - and then reformat your hard drive.
Mar 07, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
