Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Stacked Matag washer & Dryer (Dryer on ...
By larsonboat on Sep 11, 2007
1)Dryer works fine.
2)Washer will spin dry if I position timer to that spot. When I open spin stops like normal. Switch must be working ?
3)Timer sounds like it is moving.
4)Water will not come in I don't hear a click sound like normal. (like no electric)
5)Washer will not agitate even when I move timer to that spot.
Any suggestions ??????
Comments:
Sep 15, 2007
- I did everything you suggested I found all hoses were clean. I checked valve and connected to 120 and it worked. I checked wires leading to valve and they were getting some electric but not what it should be. After tracing problem I found a 1 amp overload protective fuse that was bad. I replaced and ALL IS WORKING NOW. I would suggest people check fuse first when no water supply into washer. Easy fix and easy to get to. Thanks for help !
Best Solution
posted on Sep 11, 2007
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2505 votes
Opening door while spining should stop the machine.
Since no water comes in, the agitate stage will not work even when the timer will be on this spot.
Check first the filters on the inlet water line (both sides).
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Good luck !
Comments:
Sep 15, 2007
- Thanks a lot for the information !
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
When the washer is agitating the tub bangs loudly The load is in balance
Answer
maytag neptune mah5500 spin basket moves from front to back is loose and the whole washer bounces... (More)
Answer
my lg wm 14225fd is making a banging popping noise and oe is showing on the display panel
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
