I want my dvd to work with multy region. hy system is OSX by Mac.
  • 432 Answers
Videolan ( http://www.videolan.org/vlc )
That should allow you to play any dvds ( as long as you go into system preferences ) and select vlc as the default dvd player by going into cd's and dvd's section.
If you want to make your drive region free then there is the possibility it will kill your dvd drive if not done correctly as per here
http://www.doom9.org/index.html?/rpc1.htm
http://tdb.rpc1.org/
http://forum.rpc1.org/portal.php
All flashing of dvd drives needs to be done under windows so I would advise using bootcamp and not vmware fusion or parallels as that is just a virtualisation of windows not actually running windows as per using bootcamp.
I take no responsability for what you do with the information provided and am only answering your question so be warned.
I would advise just using VLC that way it will still work but without the need to flash your dvd drive.
There are windows utils but I dont think you can get os x utils.
Unless you use mac the ripper or something of the sorts. There are dvd decryption utils to decrypt the dvds to your hard drive but you will have to google for these as I am not going to help with how to get passed the css encoding on dvds as this breaches copyright.
Posted on Apr 13, 2009
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
Dvd codes lg
Hi Elizabeth. Not all DVD players are able to be made "multi region". The model numbers of DVD players that are multi region have the same model number as a "home" region player. There is no difference in the appearance of the unit. If it was sold to you by a retailer on the understanding that it could be made a multi region, then I suggest you call them ask ask for the code. Quite often, there is a procedure to follow when converting a DVD player to multi region - along the lines of - place the non region disk in the tray and press buttons X, X and X. I know this doesn't answer your question but I hope it gives you an explanation!
Aug 21, 2014 | Audio Players & Recorders
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
Jun 07, 2013 | Pioneer DV2032K All Multi Region Code...
Sony DAVSR4W System DVD! This DVD System Its Multi-region DVD? Can this DVD plays DVD's Region 1 America?
Although it may say it's multi-region what that may actually mean is that the unit can be re-programmed to a different region. A lot of DVD/Blu-ray devices allow up to 5 changes of disc region. So it may only be able play one region discs at any particular time.
Jan 21, 2011 | Sony DAVSR4W System
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
RCA DVD RTD 315 with wrong region
You can try this options..hope this helps;
RCA DRA4008 / DRC220N
  1. Turn player on with no disc in the tray
  2. Press MENU, 1, 6, 7, Mute
  3. Press EJECT and exit the menu
RCA DRC105N / DRC198N
  1. Open tray
  2. Press 1, 6, 7, 1, 9 on your remote
  3. Select region code (0 for all regions)
RCA DRC230N / DRC230L / DRC232N / DRC233N
  1. Power on player
  2. Open the tray
  3. Enter 1, 6, 7, 1, 9
  4. OSD shows current region
  5. Enter 0-6 for region setting before screen disappears
    (Enter 0 for region free)
    Display shows new region assignment (displays "ALL" if 0 is selected)
  6. Power off
RCA DRC612N
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for regionfree
  4. Turn the player off
RCA DRS7000N
  1. Turn on the player while disc tray is open
  2. Go to the "Options menu"
  3. Press 8, 2, 1, 3, X (replace X with 1-6 or 9 for multi region)
RCA RC5215P / RC5220P / RC5231Z
  1. Enter 738565250001000X, replace X with the desired region or 0 for multi region
  2. Press INFO
RCA RS2030
    Turn the player on with no disc inside
  1. Wait for the menu to load
  2. Press INFO
  3. Press 0, 2, 8, 3, INFO
Apr 20, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Installing OSX 10.5 on G5 Mac Desktop Locks up
try to boot on 10.4, and then introduce de 10.5 DVD. Then the computer will ask to reboot, but with good options.
Jan 25, 2009 | Apple Power Mac G5 Desktop
Dvd player is in region 3 need multi region for model philips hts3548w/98
1.open tray with empty CD
2. press stop for 2 seconds
3. press 734466
4. on the screen region will appear press 0 for all regions
5. press ok to close then after open and insert your DVD.
Jul 15, 2008 | Sony DAV-SA30 System
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
