Question about HP Pavilion dv9205us Notebook
Does not boot
All lights on the notebook are on but it does not boot. LCD panel seems to be dead.
    Novelist:
  • 69 Answers
Please try below solutions:
Solution 1: Power Drian
1. Make sure that notebook is turned OFF
2. Disconnect Notebook from wall oullet and then remove the battery from Notebook.
3. Then Press and hold the Power button of Notebook for 30 seconds and release it.
Check the issue now. If the issue still persists then go ahead with next solution
Solution 2:
 Power ON notebook, and then use the Flash light( Torch Light) to flash the light on the notebook LCD screen and check if you can see LCD screen.
If the issue persists then contact HP Manufacturer on this issue.
Posted on Oct 15, 2007
I have the same problem and it was the HD not being recognized.
Posted on Oct 06, 2007
    Problem Solver:
  • 17 Answers
Possivle lcd falure, take it out to the sun and check if you can see the desktop, or bios or anything on the LCD screen, if not, plug it into an external monitor and check if it comes on, if it does, lcd faulty, if not, laptop faulty. JJ
Posted on Sep 11, 2007
SOURCE:
Laptop screen black but flickers on FN-F5
It sounds like your either backlight is goin out in the lcd screen,,,or possibbility its your lcd inverter,,,like you said hook to external screen,,if it comes on its one of the two,,,one way to see if its backlight or not is to ,,turn it on,,shaine a flashlight at lcd,,if u see ur normal screen,,,its back light ,,,if not its inverter goin out,,good luck,,if back light,,u will need new lcd screen,,,easier if its the inverter,,,u just take off lcd bezel,,down at the bottom of lcd panel,,2 screws,,and can find easy on ,,internet and ebay,,
Dec 22, 2011 | Toshiba Satellite A135-S4727 Notebook
Monitor seems dead won't come on when computer is booted up.
Is the power light on the front coming on?? If not, check the power supply if you have a volt meter. Monitor power supplies die all the time at my hospital and we have to replace them almost weekly.
Jan 02, 2010 | Smart Modular PYXSCAPE SV1170 17" Flat...
The computer is completely dead, on battery and mains power cord also?  No lights, no screen resolution (not a flicker) and no HD noise at all - completely dead, but the battery (5 flashing LED's on...
well..it should on power along..seems that perhaps the motherboard is unhappy..here's something to try..remove battery..flip over the computer, open the panel with memory..ground your hands on metal..then remove and re seat memory sticks(be careful to NOT touch the gold fingers). close it back up..plug in wall ONLY, try it again.
Nov 28, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Not responding for power button when i press
Hold it down for 15 seconds,if it goes totally off,change your power setting in the control  panel
Oct 10, 2009 | HP Compaq Presario R4000 Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
My new itouch will not boot up. It just seems to be dead
Check the wall outlet where the Power Transformer is plugged in and verify that it has current by using a lamp or something like that. If ok, then...
Check the laptop battery for charge state. The indicater light should show full or good charge. If not, the battery could be dead....
If no current from the adapter, the battery goes dead in 2-3 hours of use.
Daniel Bonnici
Mar 27, 2009 | Dell Inspiron 1525 Notebook
I have a NC6000 that will turn on the screen for about 2 seconds during boot-up. everything else seems to work ok-- it aquires a wireless link but the screen is dead. If I turn it off and back on rhe same...
Usually it's in this order. Inverter, lcd / backlight, gpu
A local repair shop would be able to confirm which one. Or you can just order a replacement from ebay for about 10-15 and try replacing it yourself. It's not hard.
Feb 21, 2009 | Compaq NC6000 Notebook
Booting
Press the FN F5 screen to see if you can toggle the screen on. If you have a external monitor plug it in to the notebook and see if you have video. If it show in the external monitor your LCD screen has gone out.
I hope this helps.
Feb 19, 2009 | Acer Aspire One PC Notebook
HP Pavilion dv9205us Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
