Question about IBM (25P3294) Motherboard
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios update found". How this erorr can be removed? Thanks
  • IBM Master
  • 5,660 Answers
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Posted on Apr 19, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • IBM Master
  • 2,226 Answers
Cpu is cooked it will not start up. would get new board after that.go on ebay its cheaper that way jim.
Posted on Nov 16, 2011
Toshiba equium l100 186 laptop Can I replace the
you know how to install the processor on the laptop ?
Sep 11, 2013 | Computers & Internet
Cpu suport
Going with problem heading stating ->
IBM 73P0595 motherboard > CPU Support > and previous problem statement ->
"I have updated my processor from INTEL Pentium d 820,2800mzh 1500mzh to INTEL Pentium d 945,3400mzh....."
Let's take a look at the IBM 73P0595 motherboard specifications, first;
http://www.epinions.com/specs/IBM_System_Boad_W_O_POV_10_100_73P0595_Motherboard?sb=1
http://www.ebay.com/itm/Lenovo-73P0595-ThinkCentre-M50-A50-Motherboard-SOCKET-478-2-4GHz-Intel-CPU-/200870757822?pt=Motherboards&hash=item2ec4d485be
A) Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
B) Intel 865G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
The Intel 865G motherboard chipset DOES NOT support dual core processors.
Does NOT support an Intel Pentium D; 820 OR 945
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.2865_nm.29
Those two processors also use the LGA 775 processor socket.
(Socket T,
http://en.wikipedia.org/wiki/Socket_T )
What did you base your CPU support on?
Was it the fact that the Intel 865G motherboard chipset, will support Intel Celeron D?
http://en.wikipedia.org/wiki/Celeron_D#Celeron_D
The Intel Celeron D is NOT a dual core processor,
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families.
The D suffix actually has no official designation, and does not indicate that these models are dual-core.
It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M......"
Not the IBM 73P0595 motherboard we're talking about?
OK.
Let's just base it on the statement that you tried to upgrade, from an Intel Pentium D820 to an Intel Pentium D945,
http://www.fixya.com/support/t13549945-update_intel_pentium_d_945_procesor
What motherboard are you using?
Motherboard in a HP Compaq DC7600 Desktop PC?
http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Scroll down to the bold subheading -> Processor and Speed
Intel Pentium D820 at 2800MegaHertz (2.8GigaHertz),
with 800MegaHertz Front Side Bus, is supported.
(800MHz FSB)
Probably came with your computer, huh?
Intel Pentium D945 at 3400MHz (3.4GHz), with 800MHz FSB is supported also.
This can be seen by the specifications of the motherboard chipset, also. The Intel 945G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
Scroll down to 945G in the left column. (Last one listed in chart)
Apparently you just needed the 786D family Processor Microcode Update, or did that not work out?
Awaiting reply,
Regards,
joecoolvette
(How did I come up with the HP Compaq DC7600, anyway?
Did you add it in a Comment, and it has been removed, or what?
!O_O! )
Jan 02, 2013 | IBM (73P0595) Motherboard
I have an old IBM Netvista 6794 pc with its original IBM motherboard that it came with P4 pc with a 2.0ghz cpu. Now I want to change the processor. My question is can a 3.6ghz or 3.4ghz p4 intel cpu work...
Unlikely, I would think that the best processor you could use would be a 3.0Ghz or maybe a 3.06Ghz. If you look at the motherboard part number you will be able to find out from the manufacturers what the fastest CPU is. A lot depends on the FSB on the mobo and the Bios version. You need a "Socket 478" processor I think you will find that the processors you are looking at are "Socket 775" ( this is the fitting socket for the processor) .
Feb 11, 2012 | Intel Computers & Internet
I'm looking for the capacity of this motherboard like what is the biggest processor stuff like that
try this one. There is absolutely nothing other than sites where you can buy an IBM motherboard, I even searched the IBM site. I did find this link as IBM systems often use INTEL motherboards but are referred to as IBM boards.
If the components line up properly this is your board.
http://downloadmirror.intel.com/15322/eng/D845G_Boards_TechProdSpec.pdf
Nov 11, 2011 | IBM (03R0329) Motherboard
Processor is working ram is working but no vga
mother board demage replace it and buy new one
Nov 23, 2009 | Intel D845GVSR Motherboard
Everytime i start my pc there is always an error say cpu ucode error f1 to resume
You need an other BIOS driver.
Intel
P6 and NetBurst micro-architecture microprocessors may contain design
defects or errors known as errata that may cause the product to deviate from
published specifications. Many times, the effects of the errata can be
avoided by implementing hardware or software work-arounds. Errata and work-
arounds are documented in the appropriate processor specification update,
which can be found at www.intel.com. Intel P6 and NetBurst micro-
architecture microprocessors include a feature called "reprogrammable
microcode"
, which allows certain types of errata to be worked around via
microcode updates. The microcode updates reside in the system BIOS and are
loaded into the processor by the system BIOS during Power-On Self Test, or
POST.
Jul 10, 2009 | ASUS Computers & Internet
What is the minimum power supply for mobo:ibm usa p6 2001?will a 250Watts work?
it depends on what peripherals and processor you're using. If you're using an under 100 watt processor, a 250 should work fine if you're only running one HD, one DVD-RW, and a very modest video card.
The fancier your processor is in it's revision line, the more wattage it draws, the more hard disks, cd-rws, pci cards etc you use.
You also may want to consider uptime requirements, and usage percentage. if you're running constant loads, power supplies don't like that, and the capacitors can get burnt up. Servers, video processing, etc will tend to require more than rated supplies just because 100% use of even close to rated wattage (and you will be very close) will tend to cause the maximum design heat to be produces, possibly blowing out capacitors etc in the power supply, causing downtime.
The brand name of the power supply matters too... if you're using a no-name chinese brand, i would be leery about their "rating", as it's probably peak for only a short time rating...
Apr 19, 2009 | IBM Computers & Internet
Upgrade processor for laptop?
After the Pentium M branded processors, Intel released the Core branded dual-core mobile Yonah CPU with a modified microarchitecture. Pentium M branded CPUs can be considered as the end of the Intel P6 microarchitecture
Sep 13, 2008 | Acer Aspire 3680 Laptop
Procesoor problem...
You can go to Intel's website under support. Follow through an pick product type until you run into processor spec finder. If you look at the cpu, you'll see letters and numbers starting with SLxxx. An sSpec Number can be thought of as a specific sku, or version of a processor with its own set of characteristics such as Core Speed, Core Voltage, L2 Cache Size, etc. Every Intel cpu has it's own unique sSpec number. I hope that helps.
Jul 11, 2008 | Intel Motherboard
IBM (25P3294) Motherboard Logo
2,035 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
