Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Where is the Alternate Valve ?
Where is the Alternate valve on a SMEG DWF614SS dishwasher. It keeping showing E 8, which when I looked it up was the Alternate valve. Found the part online for £50 direct from SMEG. Took the back and sides off but can seem to see it ? Help ?
  • pd_marshall Apr 13, 2009
    Does anybody know here the Service Manual is online to download
Water doesn't get in into the dishwasher I already checked water filter at the intake and it is ok
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 05, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
DWF614SS smeg dishwasher E8 error code
Thanks to hijoloo for pointing me in the right direction. The offending part is the diverter valve, a paddle inside blocks one of two outlets in turn actuated by a micro switch, a motor and reduction gears. Check switch for continuity with multimeter (ohms) then check motor and gears turn freely by hand. My problem was a stiff paddle due to limescale. Soak in boiling water to free off then oil cog (externally) and rebuild.
turn the washer on its side and open up the bottom black plastic plate, than disconnect the two black hoses from the white pumphouse in the middle of the washer. disconnect the connector and open carefully the housing by removing two screws and the motor. check the switch and clean the white housing. Check also if there is nothing inside the rotorhouse. after this build every thing back and hope that its running. it worked for me. succes!
hijoloo.
Apr 12, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
Dishwasher manual
Hi Rosemarygard,
You filed this question under Smeg DWF614SS. You can get the manual for that model here- http://www.smegtech.com/site/smeg/pdf_libretti/19590081906-GB.pdf.
Searching for model M4608AL isn't leading me anywhere, so hopefully it's some sort of subcategory of the DWF61466. If you realize that your Smeg is another model, go to this page and type your model into the field on the left- http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN.
I hope this helps.
Jan 25, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Instruction Manual
Hi Rf56,
The manual is located here- http://www.smegtech.com/site/smeg/pdf_libretti/19590081906-GB.pdf.
You may already have Acrobat on your computer, so try to access the manual first. If you cannot access it and they do not automatically take you to a place to download/update Acrobat, you can download the latest version of Acrobat here- http://get.adobe.com/reader/.
Feb 11, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg dishwasher problem
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
Jul 20, 2007 | Smeg 24 in. DWF614SS Stainless Steel...
Will not drain and shows E6 error code
I had this problem and eventually found a small piece of mussel shell in the bottom part of the machine, it seems they are very sensitive to the tiniest fragment of debris.
Sep 24, 2006 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
243 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Garth Jackson
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
