Microwave Ovens Logo
Cristian Buenrostro Posted on Sep 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you reset a whirlpool wall microwave oven
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on Sep 23, 2013
William Miller
Level 3:
Answers
9179
Questions
Helped
4478272
Points
21747
A reset may not correct your symptoms, which you did not reason, but here is how to do a "hard reset".
Unplug the oven's power cord or turn off its circuit breaker for about a minute, then plug it back in (or turn the breaker back on), then set the clock.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 27, 2008
SOURCE: How do I remove the
Whirlpool customer service is here and you can enter your model number on that page to download your owner's manual, installation instructions, etc.
The installation instructions will show you how it went up and that will help when you remove it.
Anonymous
  • 294 Answers
  • Posted on Apr 05, 2009
SOURCE: paint coming off inside microwave oven
HELLO' WITH IT BEING INSIDE A MICROWAVE I'LD ALSO BE WORRIED ABOUT RADIATION POISON SOUNDS LIKE ITS TIME FOR A NEW MICROWAVE
Anonymous
  • 3 Answers
  • Posted on May 25, 2009
SOURCE: Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
1helpful
Change light bulb microwave
If your owner's manual doesn't cover it, then you will have to do some disassembly, and may have to remove the oven from the wall, depending on the model number, which you did not mention.
But since you posted this is the Whirlpool microwave section, I'll assume that's it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Whirlpool mivrowave W10292071A MH7140XF Microwave Oven
My whirlpool microwave hasn't worked sice powers outage. Is there usually a reset button or fuse, somewhere
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • 0helpful
    I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
    Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
    1helpful
    How to remove the unit from the wall?
    there is 2-3 screws in the top of of your microwave that go the cabinet and it should have a bracket on the wall that the microwave should hinge off the wall from
    Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
    Is there a wall behind where the microwave is to fit?
    Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
    Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
    No Power Whirlpool MH7140XF
    does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
    Top Microwave Ovens Experts
    ZJ Limited
    ZJ Limited
    john h
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
