Question about Acer AL1914 19" LCD Monitor
Monitor problems Well my EAST class has an acer monitor that will not turn on. The little green light that normally comes on, won't. What could be wrong with it. Thanks, GHSeast
  • Anonymous Feb 25, 2008
    I have a similar problem with my Acer al 1914, but the power led flashes about once every second and sometimes I cannot turn it of from there. It seems like the power is not quite getting to the circuitry. There is also a split second hum with each pulse of the power led, but the monitor will not come on at all.
  • Ictinus May 11, 2010
    My AL1914 is dead, 2nd one already. The other one I had repaired by Acer... but reading this I want to try it myself first (no warranty anymore anyway ;)
    Bit I dont know how to open it. I unscrewed the screws, but I cant open it.
    Any suggestions on what I am doing wrong?
    Thank you
Same problem ....had 3 acer al1914 flatscreens with same problem.
3 capicitors in the powersupply blown 470 uf 25 volt
replace these with high quailty and high temp ones
and problem solved.
Powersupply heating up these caps and dries them out
and are faulty due to this.
You have to open the flatcreen to get acces to these
and have to desolder and solder the new ones back in.
Easy job if have some soldering skills
Hope this helps
Posted on Aug 07, 2008
How can I remove the the back area of the monitor?
Posted on Mar 06, 2008
    Scholar:
  • 135 Answers
The power supply has probbably blown. Not repairable by unskilled labour unless you would like to check the fuse which is a little round black item near the area where you plug the unit into mains. be careful when removing the back cover. first the screws then it unclipps from the grey front frame. do not put pressure on the screen itself. It may damage. Good luck, Kind Regards Justin (Justronics S.A.)
Posted on Nov 20, 2007
SOURCE:
Moniter won't come on
The problem is in the power supply board often caused by one or two capacitors that open, some will show a bulge at the top making it easy to spot.
Mar 23, 2012 | Acer AL1916W 19" WideScreen LCD Monitor
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
My acer monitor
I have answered this in other threads but to reiterate....
The Gray rectangle "No Signal" I use a Power Strip and Turn off as soon as it cycles back to Normal screen. It is so much easier then to unplug and Plug back in when it does happen.
As for the Newer Problem(s) and I too have had mine for only couple of years... Copied from Previous post
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Feb 02, 2009 | Acer X241Wsd Monitor
Acer 20" LCD AL2017 does not give a picture @ all.
You can look on eBay for BACKLIGHT FLUORESCENT BULB for your model.
They're around $20.00.
Dec 25, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Acer AL1914 19" LCD Monitor Logo
258 people viewed this question
Ekse
Alun Cox
