Question about Electrical Supplies
Thanks....and another question blueextc3221 was so right when I opened 2nd floor 3 way switch,there were burn marks on the face plate and an unsecured wire. It's hard to tell which,if any, is a ground wire ...they are all wrapped in fabric (1910 Colonial). I can see in the back of the junction box that 2 metal covered conduits lead into the junction box...one from above and one from below...each has two wires coming from it. The new 3 way switch I bought has 3 screws and a ground wire screw. Any suggestions?
  • Samuel Charles Spriggs May 11, 2010
    Do I understand that there was once a functioning 3-way switch connected to these two cables (one from top one from botom) in this junction box?
    President:
  • 1,723 Answers
Go to google, knols is under the 'more' section. I have a knol called 'Electrical Troubleshooting for Dummies'. There's a section in there on 3-way switches that will help you.
Posted on Jul 04, 2009
NCr and nPr
Look your calculator in the face. Find two keys one marked nPr, the other nCr. There is third key nearby with the exclamation mark (n! or x!)
If the markings nPr, nCr,n! ARE ON THE KEYS, you do not need to press [2nd F] or [SHIFT] to access the functions.
If the markings are on the face plate of calculator you must press [2nd F] or [SHIFT] then the appropriate key.
To calculate 10P3 you enter 10, press [nPr] or [SHIFT] (nPr), enter 3 and press [= or EXE]
Mar 11, 2014 | Canon F604 Scientific Calculator
Face plate keeps opening and closing since battery went dead and was replaced
If there is a reset switch, try pressing it. The reset switch is usually a pencil tip sized indentation on the face and will not be marked or will be behind the face on the sub panel.
May 18, 2011 | Panasonic CQ-C8303U CD Player
I think I have a Leviton double pole dimmer switch. It used to operate track lighting along with an on/off light switch in the same room (different entrance). I replaced the track lighting with a fan...
You mention a dimmer and a 2nd on-off switch.
You purchased a 'double pole' switch which I believe is a 3-way switch.
3-way switch has 3 screws (plus ground screw which will not be mentioned further)
3 screws on 3-way switch = one is dark colored, and 2 are brass colored.
You can guess. There are only 3 wires and you can keep trying different combination until both switches work. Do not change wiring on 2nd switch and sooner or later the right combination will appear.
On the other hand, electricians test wires using ordinary tester, before connecting anything.
If you want to test, it takes 3 ez steps.
Here's what I would do.
1) Look at wiring on 2nd switch.
Notice switch has 1 dark screw and 2 brass screws.
If you can identify the two wires on the brass colored screws, these are the 'travelers' and same two wires connect to brass colored screws on new switch. And then last wire connects to dark colored screw.
2) You have noted the wires carefully on dimmer, so remove dimmer, and separate wires for testing.
2nd switch is moved to down position.
We are NOT going to test wires on 2nd switch.
We are just testing wires at old dimmer.
Turn on power.
Power is on.
2nd switch is in down position.
Test each wire to bare ground wire.
One and only one wire will light up the tester.
Mark this wire.
3) Change 2nd switch, and move 2nd switch to up position.
Test each wire again to bare ground wire.
Again only one wire will light up tester.
Mark this wire.
If same wire lights up tester each time, then this is the Hot wire and it connects to new switch dark screw. And the other two wires go to brass colored screws.
If a different wire lights up each time, then these two wires are 'travellers' and they connect to each brass colored screw. And the last wire connects to dark colored screw.
Dec 16, 2010 | Electrical Supplies
Disc drive
Put it down. They run very badly if they're upright. You need to put it on the floor flat and if needs be, open the door with a paperclip. You'll need a thicker paperclip and have to turn off the xbox first to avoid breaking the mechanism. Take off the face plate and you'll see 3 small holes below the tray. Push the clip in hard on all 3 til you find the right one. No damage will be done to the non tray opening door holes, so don't worry.
May 12, 2010 | Microsoft Xbox 360 Console
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
I HAVE A 1999 SATURN SL PUT NEW CLUTCH IN AND A NEW PREBLEED CLUTCH MASTER CYLINDER AND SLAVE CYLINDER,HAVE GOOD CLUTCH PRESSURE WHEN PUSHING DOWN PEDAL BUT CLUTCH IS NOT ENGAGING. ANY IDEAS?
Are you certain you or your mechanic installed the clutch plate facing the right direction? It is usually marked on one side to tell you which way to face it. I have personally done this and had the same issue, if the hub portion of the plate is rubbing on the flywheel it won't kick out or in all the way, and if left it can cause damage to the flywheel.
Good luck.
Good luck.
Apr 04, 2010 | 1996 Saturn SC
Turning the 4 statues, which way do each face?
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
I got this from gamefaq
I hope it helps
Dec 30, 2008 | Sony Uncharted: Drake's Fortune
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
The sanctuary
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
hope it helps
Dec 27, 2008 | Sony Uncharted: Drake's Fortune
Electrical Supplies Logo
106 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
