Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
I've always had drops of water exiting the steamer when I'm steaming my milk. Actually if I fill my mug up 1/2 with milk, by the time I get the milk hot enough (no foam), the level of milk is now at 3/4. Is this normal, how can I get my steam dryer? My espressos are weak, I have the grinder set to 0 or 1, I thought the finer the grinds the stronger the brew? When my shot is pouring out it starts really dark but a second latter it looks very watery.
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check
if water is dripping right at the center of the filter, if it is
dripping on one side because the orifice is clogged, that can result in
weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure
that you are not leaving the machine brewing for a time that is too
long, and Italian coffee cup is very small, approximately one regular
shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This
are the trickiest ones, you need art and practice to get a good
espresso with a Moka, but when you learn, the result is better than
what you may get with an home electrical espresso maker.
The frame
on the hob must be not too strong, and the mixture coarse but well
pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Jan 29, 2018 | Coffee Makers & Espresso Machines
Jan 01, 2015 | Top Vacuums
Apr 12, 2014 | Sunbeam Cafe EM6910
Aug 01, 2012 | Coffee Makers & Espresso Machines
Jan 17, 2011 | Microwave Ovens
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
Sep 05, 2010 | Saeco VIA Venezia
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
267 people viewed this question
