Question about Bosch Classixx WFC 2465 Front Load Washer
My washing machine keeps blowing he fuse in the plug
I have a bosch classixx every time i try to but washing on the fuse in the plug blows,it washes for a little time first.i have tried to put it on a cold wash and the same thing happens
  • Anonymous Mar 29, 2014
    Time keeps resetting and wash time keeps going
  • Bosch Master
  • 19,396 Answers
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Posted on Apr 13, 2009
No lights on bosch washing washer
check to see if there is any power going to the main board and if not you have a problem with a plugin, but if power going to main board then you have a fuse blowed, ie ceramic fuse.
May 05, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch wfk2801 has died and keeps blowing fuses, I've changed the carbon brushes & no change, every time i turn it on it seems to be struggling - the motor moves a little, then crackles a bit then...
hi there.......from your description of the fault it would appear that your motor is short circuit.....remove the plug from the motor replace the fuse and switch the machine on...if the fuse dosent blow replace the motor..be careful its also possible the control module is also damaged
regards Sir Galahad
Aug 18, 2009 | Washing Machines
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Power
just done a simple wash no problems, put on another wash on and a key appears where the timer appears and bleeps like it has finished a wash. could anyone tell me what this key means so I can carry on washing
Oct 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Jun 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
1,410 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
