SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software. Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key. They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
SOURCE: I have lost the original software CD of Nikon Coolpix L18 camera. How can I get a download?
Most often the manufacturer will have a support and downloads area on their website. You may find what you need here: http://www.nikonusa.com/Service-And-Support/Download-Center.page
SOURCE: NIKON DIGITAL COOLPIX L18 LENS OPENED FOR EVER NOT CLOSING.
works on all brands
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and in between the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help+++++Thanks for using FIXYA
Testimonial: "I AM SO MUCH DELIGHTED TO SEE SUCH A WONDERFUL SOLUTION. I AM EVER THANKFUL TO YOU SIR. I WILL TRY THIS AND HOPE IT WILL DEFINATELY WORKOUT TO ME. "
SOURCE: Nikon Coolpix L18 display shows
what??im not gettin a new camera, i just got this one less than a month ago. why does it do that?
SOURCE: coolpix l18 no battery level indicator
The low-battery indicator only shows up when the battery level drops below a certain threshhold. Normally there is no indication on the screen of the battery status.
