Question about HP DeskJet F380 All-In-One Printer
Every time i go to print the printer on line shows error and says paper run out when the paper is loaded and won't allow me to do anything, so I have to add printer again which takes for ever,its ready but won't print still keep doing it all the time really frustrated as cannot print urgent letters. I have to add printer each time and still don't work...please help before I go in sane HP deskjet F380.
  • bhattaruna Apr 13, 2009
    it always is
  • Anonymous Apr 13, 2009
    my printer is online, i just put new ink in it but still says theres none and that theres an error wont do anything but it still printed the self-test
  • 34 Answers
Make sure it`s pushed in enough
Posted on Apr 13, 2009
How can I fix error 6000
Hi there
You don\'t mention anything about "blinking lights". This can help with diagnosis and correction. Please ind below some recommendations:-
This is a line feed error. It also should be flashing 3 times for this error on the on/off button.
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 30 seconds
  • Power on.
Solution 4: one of these parts could be faulty:
  • Timing sensor unit QM2-2683
  • Timing slit disk film QC1-6229
  • Feed roller ass\'y QL2-0925
  • Platten unit QM2-2923
  • Logic board ass\'y QM2-3078
  • Paper feed motor QK1-1502
My preference for sorting this problem would be number 2 if you experienced a paper jam prior to the problem.
Hope this helps.
Aug 27, 2014 | Canon Pixma MX432 Wireless All-In-One...
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Epson stylus T13 general error
based on my experience my printer show general error every time I print when the printer is about to load paper.. so i check out the loading and found out that part of it was damage and fall off, i don't know what to call it, but it looks like a hook of some sort.. maybe for triggering the loading mechanism that's why my printer give me error everytime it's about to load paper.
So, my advice is to look inside your printer and see if there are foreign object or fallen parts.
Mar 12, 2011 | Epson Office Equipment & Supplies
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Ghost prints on HP-1300
The cartridge could be bad. Just saw same issue earlier on another HP doing the same. Inspected the fuser and it had a place it the middle that the teflon coating was worn off. Try cartridge first, then look at the fuser with flashlight. Do not stick anything into the fuser. Make sure machine is powered down,unplugged and allow it to cool down before attempting to touch area. It will burn you, they get hot!
Feb 13, 2009 | HP LaserJet 1300 Printer
Show the load paper error
There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
Jan 01, 2009 | Printronix Line Matrix P5005B Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
