It sounds like it could be the main power board. If you have 12V going to the board and the fuses are all ok then the power board would be the next item that could cause this issue. I would recomend a dinosaur electronics replacement board. They are a high quality aftermarket product. You will require the P711 board by Dinosaur. ArctiCold Refrigeration We keep it cold
SOURCE: Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
SOURCE: I have an old RM
Easiest and cheapest solution I see is to by a simple 12 Volt toggle switch and cut one of the wires from board to 12 VDC element and run it to a toggle switch mounted inside near fridge. One terminal on switch will be wire from board, and other terminal on switch will have wire going back to wire cut going to element. Simple and cheap , on, off, solution, just be sure to use heavy enough gauge wire, and add an inline fuse if you want for added safety.
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
