Question about Invacare Pronto M51 Power Wheelchair
When running the wheelchair at top speed there is a slight grinding noise in the drive train. is there a way to grease or oil the drive?
  • 40 Answers
No,the motor-gearbox mechanism is sealed. You`ll probably need new motor brushes which you can get from a dealer or a new motor and/or gearbox.
Posted on Apr 13, 2009
Grinding noise in either motor, gearbox or drive shaft on low speed going uphill. Gets worse when going faster. Souns like something needs oil change or top-up.
Look at the universal joints on the 2 ends of the drive shaft. The hubs may have dried up and wore out you might be grinding metal. If so, you need to replace the universal joints before the drive shaft falls out.
May 16, 2016 | Motorcycles
Cuisinart stand mixer making grinding noise. What is it and are there directions for fixing/replacing it?
inside those mixtures there is grease or oil to keep the gears running smoothly. look on your counter or where it is stored and look for grease or oil. if there is then your best bet is to find a repair shop. ask where you got it from, they should be able to hlp.
Oct 29, 2014 | Cuisinart 5.5-Quart Stand Mixer SM-55-...
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
Oct 17, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Grinding gearbox
Check the oil level ,if need be pump some LM grease into the gearbox about a GREASE GUN FULL will do this will seal up any leaks once its warm and melts in a bit ,the noise was the lay shaft bearings or the drive gear shaft bearings to the crownwheel ,faily common on peugeots and citreons but make sure you check the level use EP90
Oct 11, 2013 | Peugeot Cars & Trucks
Kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
Dec 10, 2009 | Kenmore Sewing Machines
Question regarding KitchAid mixer, Model K45ss. The vertical mixer shaft has play in the gearbox, it makes worn gear noises at all speeds. I adjusted the speed control to manual specs, the speed control...
Yes this indeed does sound like you have a problem. There could be a couple different cause of this noise. If your main drive or worm gear has been damaged, it is likely to not run at all or jam up. So i think this is not the problem. There is however a codder pin located inside the transmission gears this can be seen by removing the upper housing of the unit, and then exposing the oil and gears. clear away the oil surrounding the gears, and save this grease for later. After this you should be able to visually see this codder pin AND the gears, rotate the gears while inspecting them and the pin. If the pin is slightly bent or broken this will make the grinding noise that your are talking about, while still operating and driving the unit. part number for the codder pin is 9705444. If however the noise is coming from the motor area this could indicate a worn or faulty motor bearing. This can cause the motor to operate on an angle and can cause a rubbing noise from the cooling fan or the winding of the motor itself rubbing on the mixer housing. Part number for the braket and bearing is 3180526. both are relatively cheap and easy to replace. If you find and fix the problem be sure to inspect or change the oil as this can often have metal chunks and other particles. Hope this Helps
Thanks
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Asko T780 Dryer Vibrating/Grinding noise
Sounds like a bad roller. You'll have to remove the drum to get at them. Even a free one may make noise at speed. Use high temp grease. Also check roundness. And don't forget the belt tensioner roller, just don't get any grease where the belt touches.
Apr 23, 2009 | Asko T781 Electric Dryer
94 jeep cherokee 4.0l automatic 3 speed transmission problem
THIS IS 2 LITTLE PLASTIC TABS ON THE FORK IN THE TRANSFER CASE.
Jan 26, 2009 | 1996 Jeep Cherokee Country
Front drive train or axles?
Welcome to fixya
could be one of those but lets hope not it could also be the front bearings if it is the bearings it runs around 300 to fix if it is drive train or axles your talking a lot more money
OH check the break pads just thought of that if the pads are low it will make a noise to pull wheels off and check breaks first
hope this helps you out have a good day :)
Jun 30, 2008 | 1996 Toyota RAV4
Invacare Pronto M51 Power Wheelchair Logo
266 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
