Question about Zanussi FLA1001W Front Load Washer
Washer not woring properly
I have an old zanussi FL 1081 first when i go to put it on a programe it makes a big timer noice now when i use the programe that doesnt make that noice it takes ages and the comfort part of the draw stays full of water.Also the clothes are full of bits after the wash have cleaned the filter again please help me
  • 66 Answers
Check your water valves ere not open cicuit if not may be your programmer
Posted on Sep 14, 2007
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
How do i take the timer off a zanussi fl 828 its the old clock work type been a fantastic machine its just the resistor on the top has blown
Most of these timer based on mechanical action is now being out of production. so only if you are able to get to salvage one from a repair store will this be recommendable as buying a new one for a higher price when the machine is old. The stepper motor or the supply to it can be checked and if this is working you can replace the resistor which seems to be blown.
Jan 20, 2013 | Washing Machines
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
How to change door seal on zanussi fl 1080 . how do i remove old torn one and fit new
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
Thank You for contacting
Aug 03, 2009 | Zanussi ZWF1440 Front Load Washer
Softener still in dispenser after wash cycle
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me
For more help go to live chat.
Jan 30, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Nov 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Sep 12, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
