Question about Lexmark Wheelwriter 1000 Typewriter
Beeps 6 times, lights blink
When I turn the typewriter on, it beeps 6 times and lights 1 & 2 start blinking. According to my user's guide, this means the printwheel and/or ribbon needs to be replaced. So, I replaced both and the problem continued. I then replaced the batteries, but nothing changed. I'm beginning to think the machine settings have been lost. Any help?
  • Anonymous Dec 11, 2007
    I have the same problem and I tried what is suggested. The black flag moves fine however the typewriter is still not coming on or printing. The only way to tell that there is power is the 1 and 2 lights are flashing on and off.
  • Anonymous Jan 07, 2008
    HELP MY MACHINE IS DOING THE SAME THING. NONE OF THE SOLUTIONS ARE WORKING
  • Lexmark Master
  • 3,594 Answers
The prinwheel sensor is likely the issue.  Move the carrier to the right, on the left side of th carrier toward the rear of the machine there should be a small black "flag" sticking out of the carrier.  this should move freely in and out if it is not there or does not move the machine cannot detect the printwheel the sensor will need to be replaced.
  You ca also check for debri down in the area where the printwheel sits.
Posted on Oct 24, 2007
SOURCE:
I have an IBm Wheelwriter 5 typrwriter. When I turn it on the line space lights blink and I cannot type or get the casette to move at all.
How many beeps? Which Lights? Blinking together or sequentially? These will help to determine the problem.
DickyO
Aug 04, 2011 | IBM Wheelwriter 6 Typewriter
Typewriter beeps continually and first and third lights from the bottom right blink when I turn machine on. Beeping stops after 30 seconds or so, but lights continue to blink and no keys work. I changed...
Be sure the printwheel id properly installed, remove P/W & check for dirt and debris in that area. If you have air in a can try blowin out that area.
DickyO
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
Won't type. blinking 1 and 2 lights. Beeps 6 times when you turn off and on
The keyboard is going bad. You can try my tip under WW1000 or contact Geo. Beters Co.
@ 800392-8085 for a KB rebuild. Tell them O'Reilly sent you.
DickyO
Nov 05, 2010 | Lexmark Wheelwriter 1000 Typewriter
The spacing lights
Check to see that the printwheel is properly installed, then check for debris in the P/W area.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
Wheelwriter 15 series II
The ribbon drive motor might be n/g. I think 6 beeps is the ribbon motor located under the gear on the ribbon cartridge.
Feb 08, 2008 | Lexmark Wheelwriter 1500 Typewriter
No start up
If your WW3 has batteries it must have spell check or printer options there is a small door on the top right of the machine.
open the door and unplug the plug you find there and try it.
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
489 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
