You most likely have the 12 volt permanent connected to the switched supply lead you need to identify which wire requires the permanent and the wire that requires 12 volt switched this will only appear when you turn your car key to acc position , it's normally a yellow or orange wire your looking for but check your models schematic.
have a lookn on the wireing on the back of the unit. you should have 3 cables that are dedicated to powering the unit. one is 12v constant power, one is your ignition and the other your earth. ensure that your 12v power cable and ignition cable are connected up correctly.
Hello I am installing a JVC- kw-av71bt to 2 audiovox headrest monitors. can you tell me the easiest way to run the rca cables from the headunit to the monitors.
http://books.jvc.com/booklist.asp?Model=KW-AVX706
This is a link to JVC support site where you can download the manual.
However for a quick jump start. It is the LIGHT GREEN cable.
Regarding the phone, reading the manual will be your best solution. Plus it is good to have a manual around.
dreamsystems
