Question about JRC Plot 500F GPS Receiver
Using a cable to my pc to transmit data my jrc showed error
I want to transmit data to and from my pc from my jrc plot 500f. i made a cable as per the diagram in the manual hooked it up and followed the steps. when i tryed to transmit from my jrc to my pc my jrc came up with error after a few seconds. do i need software for my pc
Yes. There used top be a download at www.jrcamerica.com but I can't find it now. I bought the required null modem cable, used the intended J-NAV LINK 2300 softaware and still got the ERROR msg. If you figure it out let me know, because loading waypints/routes is very timely.
Posted on Jun 14, 2009
What to do when error;invalid DIM shows up on the screen?
INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press 2nd (stat plot) ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Sep 13, 2014 | Texas Instruments TI-84 Plus Calculator
When i preview what i wish to plot it is in black & white but plots in colour as per drawing
A preview is a quick way to show the layout of the drawing. If you want the preview in color, configure the preview options.
Aug 07, 2014 | Autodesk AutoCAD LT 2009 Full Version for...
Ti 84 plus silver edition will not fit a linear model to plotted points. when I use the function vars>stat>EQ>RegEQ it transmits incomplete data in to Y=.
Your data must be in two lists L1 (for x-values), and L2 (for y-values). This is the default setting. Open the STAT utility, go to the regression models. Select your model then press ENTER. The command echoes on the main screen. For example let the regression be something called LinReg.
On the main screen you see LinReg
Complete the command line as follows
LinReg L1, L2, Y1, ENTER
You see the statistics including the regression equation.
If you go to Y= Editor you will see that Y1 contains the regression equation.
If you have already drawn the scatter plot for your data, pressing GRAPH will superpose the scatter plot and the regression curve., and you will be able to judge the goodness of the fit.
Sep 28, 2013 | Texas Instruments TI-84 Plus Silver...
Need to connect my J-NAV 500 GPS to my laptop, however, manual doesn't help much regarding which wires to to which pins on the 9 pin "D" connector. Thanks
This device if the manual is right uses an RS232 connection, what you are goiung to look for is a nine (9) pin connection it will look similar to your VGA connection on your computer. Do not connect the cable to your VGA connection, the nine pin connector will connect to the gps unit and the other end of the connector will connect or at least should connect to your computers com1 one connection or maybe the usb connection not sure. Should note that this unit has been dicontunued and the only manuals i could find were in Japanese which i don't speak, but that should be your connection.
Hope this helps
Jun 26, 2011 | JRC Plot 500F GPS Receiver
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
DSC hookup
It appears to have a computer interface,It uses an RS232C Interface, a small D9 Socket on unit, you need a specially wired cable, to talk to your unit, with GPS software, it sends out NEMA codes to the PC. You also need driver, and software, software at the least. www.jeppesen.com/documents/.../FullCompatabilityListAug09.pdf software compatibility list above.
I looked but couldn't find a manual...
Apr 03, 2010 | JRC Plot 500F GPS Receiver
Looking 4 instruction manual 4 JRC Plot 500F GPS Receiver
Regards, Tony
Jan 28, 2010 | JRC Plot 500F GPS Receiver
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
JRC Plot 500F GPS Receiver Logo
404 people viewed this question
Top JRC GPS Experts
Shehu Pro
Shehu Pro
Are you a JRC GPS Expert? Answer questions, earn points and help others
