Question about MTX RT202 Car Audio Amplifier
Car audio I'm trying to hook up my amp and sub in my 99 toyota tacoma. i still have stock speakers in it so i wasnt sure if i should hook up my amp (mtx rt202) to my speakers, all i really wanted it for was my sub. Anyway, I got it all hooked up and everything, but when i turn on the vehicle, the light on the amp turns on (red) and music plays sounding like normal through the speakers, but not the sub. it doesnt sound any different so i am assuming none of it is working. i have a kicker sub. and the sub and amp both work fine, I just took them out of my friends car.
  • 41 Answers
Hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Posted on Sep 11, 2007
SOURCE:
My mrp m650 alpine amp power light is on but no sound. it works if i hook it to other vehicles but not in mine.
Check your speakers and speaker wires to make sure you have no shorts or grounds. Not knowing what vehicle you are putting the amp in, there is also a possibility that there may be a stock amp in the vehicle. If this is the case, you may have to rewire the speakers and bypass the stock amp.
Feb 27, 2012 | Alpine MRP-M650 Car Audio Amplifier
Hooked up a new amp but nothing comes out of the speakers, ground remote and power are al hooked up correctly, what could it be.i tried a couple of subs on it to make sure it just wasnt the sub, but...
Did you check your RCA's? I've done it a million times. I've forgotten to hook them up or I hooked them up on a amp that had a preamp output...Hope this helps
Apr 02, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Monoblock amp with DVC subs
is the amp 2 ohm stable, and are the speakers 4 ohms apiece? ohmage is indicated by a number such as 4 followed by the greek letter "omega"
if the amp is 2 ohm stable, and both speakers are 4 ohms apiece, then yes you can hook up both, one to each terminal set
Nov 27, 2008 | Car Audio & Video
DOES A 2009 TOYOTA TACOMA STOCK RADIO HAVE RCA OUTPUTS TO ADD A AMP AND WOOFER?
Yes!
Read more:
http://trucks.about.com/od/2009toyotatacomatrucks/a/tacoma_changes.htm
"2009 Toyota Tacoma trucks are fitted with an enhanced standard audio system for 2009, with an AM/FM radio, auxiliary audio input, an MP3-capable CD player and XM Satellite radio capability."
I have an '08 Tacoma, and I bought an aftermarket iPod interface with RCA jacks so I could hook up my iPod and Sirius Satellite Radio.
Jul 26, 2008 | 2008 Toyota Tacoma
MTX RT202 Car Audio Amplifier Logo
181 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
