Question about Samsung SGH-D900 Cellular Phone
Charger pins broken
The charging pins on my D900 are somehow not working. I sent the phone to CPR cell phone repair who mailed the phone back with a full charge; however, when you plug the phone into a charger the charging pins still will not accept a charge. Have taken the phone into yet another repair shop who states, "we can not repair the phone". They have recommended a desk top charging station. It appears these are only sold on UK e-bay sites, which I am very leary of. Do you have any other suggestions???? Thank you so very much.
  • 33 Answers
Charging socket needs to be replaced. smart11 is right, is pads are broken on the board, you can't do anything. Damaged charging connector can make a short in the phone, what can cause short battery life, no audio and other problems. So if there are shorted pins in the phone, even you will charge the battery out of the phone, the short inside the phone will discharge it really shortly. The reason why they don't want to replace the connector is, that it is not very easy to replace it by hand, just with hot air. They don't want to risk, that they will damage your phone more, than it is now. If you are from UK, check: CRC Group - Nottingham,they can do it. It will cost you 40pounds. If they will brake the phone, they will give you refurbished and tested one.
Posted on Sep 29, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
You must change the charge connector exept if there are broken lines on pc bord.if the are the only solution is a desktop charger
Posted on Sep 12, 2007
SOURCE:
Can't turn on my d900 with cable plugged in...
It is probably is the charging port. Have you tried a different charger?
If it is the charger port on you SGH-D900, You have 3 options.
1. get it repaired, under warranty if possible.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge
Jul 11, 2009 | Samsung SGH-D900 Cellular Phone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
D900 won't turn on , But battery is ok
Your charging port may have broken. I am seeing more and more of this type of problem. Did you try a different charger? If it is the charge port, You have 3 options when the charge port breaks.
1. Get it repaired, under Warranty if possible. About 60 dollars
2. Get a new one, runs sbout 75 dollars
Samsung SGH-D900 not charging problem repairs
Apr 20, 2009 | Samsung SGH-D900 Cellular Phone
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Charger port seems faulty and wont take a charge SGH a 437
Umm, that means it was exposed to moisture or is water damaged.
The water dmage may have caused the charg port on you D900 to short out.
2. Get a new one
Dec 04, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
2. Get a new one
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
No charge
It very well could be the charging port. As for getting samsung to repair for free, willnot happen. As long as it lasted through the warranty period they are satisfied with the design
With a bad charge port, You have 3 options.
2. Get a new one
Samsung SGH-D900 Broken Charging Port Repair
Jul 24, 2008 | Samsung SGH-D900 Cellular Phone
Problem charging D 900 and opening sim folder
The charging port on your d900 may be broken.
2. Get a new one
Jul 14, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900 wont charge or switch on..
your phone hardware might be dead , there is no way u can start it , u need to go for a service of your phone and they will flash the entire hardware and reinstall the software
Dec 28, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
152 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
