Cars & Trucks Logo
nathalie borjas Posted on Sep 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Honda says a 13 what does that mean - Civic Honda Cars & Trucks
Stephen
Level 3:
Top Expert:
  • Honda Master 21,873 Answers
  • Posted on Sep 02, 2013
 Stephen
Honda Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6209541
Points
67230
If you mean engine trouble code 13 and the Honda is older than 1996, it means the barometer or map sensor has a problem.
2006 Honda Accord. I have a 83-13 code and 61-10 code on it. How do I fix it please?
Question edited for clarity.
Question moved to model category.
83-13 is a communication problem between computers.
83-13: ECM/PCM RELATION FAILURE. 61-23 MODULATOR- CONTROL UNIT POWER SOURCE LOW VOLTAGE.
May 26, 2022
I need my car fixed soon. : r/mechanics - Reddit
https://www.google.com/search?q=2006+Honda+Accord+83-13+code
61-10 is the driver's seat belt buckle switch
https://www.google.com/search?q=2006+Honda+Accord+61-10+code
Honda seatbelt switch diagnostics. Code 61-10
Bob is the Oil Guy https://bobistheoilguy.com > forums > threads > honda... Nov 15, 2012 - I scanned it for codes and found a 61-10 (open in left front seat belt buckle switch). Since my scanner doesn't have any troubleshooting for it, ...
tip
How to check if alternator is charging.
With the car running check the voltage at the battery. The voltge should be 13 volts or more. !3.5 13.6 etc. If the voltage is 12.6 or below. Then it is not charging. Over 15 volts or higher means the regulator is overvcharging!! which can damaged the battery or even explode!
83-13 ecm/pcm relation failure how to fix it
https://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&thid=29836379#moderation-modal
Reset radio code
Acura and Honda Radio COdE Retrieval and Unlock Tips ...
? 5:13
www.youtube.com/watch?v=tgfRmBo7Pu0
Nov 13, 2009 - Uploaded by Factory Car Stereo Repair Acura and Honda Radio COdE Retrieval and Unlock Tips .... mine is Honda Accord 93, click what button to active it? .... Radioreset code in 5 minutes for a 2001+ Honda CRV CR-V Accord Civic Pilot Element Odyssey Insight ...
1helpful
2answers
The b 13 code came on in y. 2012 honda accord exl coupe. What does it mean
The b 13 code is displayed for you next service with the dealer. It informs the dealer what type of inspection the vehicle will receive along with its oil change. It will be reset by the dealer, however, you can reset it by holding down the push button by the speedometer and then turning on the key till the dash lights come on. Hold the button until the b service light flashes then release it and then push and hold again till the b service light resets
What does b 13 stand for in a 2010 Honda pilot
Well get the Manual And Look It Up or go to Youtube to see what it means or google it and read up on it
Ecm failure causes
no year?, hopeless.
my wild guess, cell; phone?
and 1983 Accord, with ECM flash code 13?
did you look here first then ask questions.
http://www.troublecodes.net/honda/
this is a Carb car right?
if car is EFI
13 means bad baro sensor, in non science terms
that means a bad MAP sensor.
the MAP is used to calculate all air flowing in to the engine
and this allows the ECU to inject a perfect fuel mix.
if 13 happens the eCu goes to limphome and sucks fuel like crazy.
13, means bad wires to MAP or bad MAP or bad vacuum line to MAP.
a tech, checks all 3, and then tests the MAP and the problem is solved. the FSM is free, ask.
really a 1983? very very old.... tjhat...
My 1992 honda accord lx battery keeps dieing aletrnator is going bad starter is almost shot but the fuse under hode the 80amp box one was blow i replaced will that help
check alternator with a multimeter engine with running you should have 13-14.5 volts anything less means alternator is bad.
2helpful
2answers
Resetting 1998 honda civic remote control
ok here is the porcedure that i have for it
Remember , these steps must be preformed within 5 seconds of eachother also all doors should be closed, radio and lights turned off
im not sure what you mean by a bypass, you can always just not use the remotes and go into the body control computer and turn off keyless entry
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
