Question about BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo) Burner
I have benq 56x cd reader it is not identified and show msg box please insert desk in drive..
  • m_yocef Apr 14, 2009
    ive got the solution it was the small cover of the tray i replaced another and it is ok thanks for all
  • 3 Answers
Are you installing from pirat cd?
Posted on Apr 13, 2009
I need sound card drivers for this machine
Hi!
Download it from the sound card official website and the most latest driver version is the most recommended one.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 06, 2010 | BenQ 656A Internal 56x CD-ROM Drive
Cd rom does not recognize any disk i have atapi 56max
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | CyberDrive 56X CDROM IDE ATAPI (CYBER56X)...
How i find download for cd-room benq model 656a-56x max
Dear Sir,
Please post questions in detail to help us to serve you better. The answer which I'll be providing you is based on assumption on the little data you have provided.
I think you need drivers for your CD ROM drive. If you are using windows XP then you don't need any driver becasue it is already there is XP but if you are using an older version, you can get the drivers from BENQ site. By the way are you still using CD ROM drives when DVD writers are available dirt cheap. Consider this as suggestion.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 28, 2009 | BenQ 656A Internal 56x CD-ROM Drive
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
How to unblock freecell
most likely he has changed the permissions of the executable file for freecell.
Go to the following location in your pc
C:/Program Files/Games
right click on freecell.exe
Click on the security tab and uncheck the deny fields for every user group.
Click Apply
Click OK
then try to open freecell
Jul 14, 2008 | BenQ 656A Internal 56x CD-ROM Drive
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Copy pic. from cd to card reader
just insert you compact flash card into your card reader and let windows to show under my computer.when you see your flash card under my computer ,enter into your cd and select the pictures files you want to copy to the flash card.Now right click you will see a pop up box ,select sendto > ,now under sendto option you will see your flash drive,just select it and your files will get copy to flash drive.
if you are unable to perform these steps just select the photo files and right click ,then select copy.Now goto your flash drive ,double click on it to open it.Now right click and select paste........that's it. your files will get copy to flash drive.
Apr 24, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
PC shows no disc in drive E
is this because i used the usb cable for another devide?
- i dont think so. the usb cable that comes with the benQ camera is the usual usb cable. i used it for other devices and still works fine with my camera again. i even used another usb cable from other devices in camera and it works fine.
is it a virus maybe?
- well you can try inserting a different device in that usb port, now if it still cant see it, its probably busted. all your usb ports are on used? wow! how about you try taking some of it out and check those ports for your camera.
Nov 26, 2007 | BenQ DC3410 Digital Camera
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo) Burner Logo
146 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
